FS: Adcom GFA-535 II
    VR3 Posts: 29,549
    edited March 2004
    Faster, (Enter Key Dosnt work :confused: ) ---- I looked over the Adcom, about midway on the faceplate there is a 'pin' ****, and I do mean a 'pin' ****, as it is barely no bigger than the point of a needle.
    Then, on the corners (to the side, barely to the front edge) of the left corner, might be on the right as well - the paint has slightly chipped away, again - not noticeable from regular view, just upon CLOSE inspection. Then there is like a splotch of w/e on top of the amp, about 1/4x1/4 of an inch, barely noticeable. Not sure what it is, might be a spot on there from stacking. Not noticeable.
    The amp is in great condition, works, looks about perfect. I packed it up in its original packing -- the original packing is styrofoam that surrounds the entire amp (covers bottum, sides, and top) --- I added bubble wrap and a trash bag around the amp, and packing popcorn around the two slots on the bottum and top packing pieces.
    I will insure it for 300 dollars -- shipping will be about 15 dollars.
    Just givin ya da details!
    Sid Da Kid
  • faster100
    faster100 Posts: 6,124
    edited March 2004
    Thanks trey, will send a money order tomorrow... Thanks.. will finish this deal via e-mail... and will report back here once i get it..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
