Opinions RT vs RTi
gacole2000
gacole2000 Posts: 255
edited May 2004 in Speakers
Hello,
I wanted to get some feedback and see if anyone had upgraded their RT's to RTi's. Is it worth the $? In your opinion, what was the upside/difference between the 2 models?
Thanks for any input, it is appreciated!
Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
  • HBombToo
    HBombToo Posts: 5,256
    edited March 2004
    I rebuilt my 55 to 55i's(surround duty) so they matched my i series in the front. I played them and tested in front for a comparison and to be honest I did not hear a difference. The only advantage was that now all the speakers match... so one less thing to stress over;)
    HBomb
    ***WAREMTAE***
  • gacole2000
    edited March 2004
    Thanks Henry, I always appreciate your input. I would have to do all of my speakers, so this would be quite an endeavor. So in your opinion, cost/benefit ratio is low?
    Have a great weekend- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • spyderman
    spyderman Posts: 678
    edited March 2004
    The RTi's have the really cool looking blue metalic driver... I've owned both and couldn't hear the diff. Could just be my ears though...
    I still miss my 55's. I wounder why Polk won't replace that line?
    RTi70 Fronts
    CSi40 Center
    RTi38 Rear
    PSW650 Sub
    Str-de1075 Receiver
    Hope is on the way!
    ABB
    VR3 Posts: 29,441
    edited March 2004
    Because the 55 didnt sell......
    The RT** line, depends on which one you are talking about...
    There are two RT lines
    RT3, 5, 7, etc
    RT35, RT25, RT55, etc
    The RT 3, 5 use a different tweeter use a different tweeter than the rest of the line (3, 5 use a Polymer, the rest of that line uses a Tri-Lam). There are VERY noticeable differences in the polymer and the Tri-Lam. To me the tri-lam dosnt hold AS MUCH detail as the Polymer in the snare, cymbal, and acoustic guitar region. Just my opinion.
    THe RT25, 35, 55 to the 25i, 35i, 55i -- There are woofer and crossover/cabinet changes I believe. The tweeters are relatively the same, therefore should sound pretty similar. I think both series use Tri-Lams. I could be wrong, Polk dosnt really provide any information on them, and were before I got into this hobby.
    The RT25i, 35i, 55i vs the RTi28, RTi38, etc -- I believe the differences are HUGE. ESPECIALLY in the high end. This is my opinion only, but the silk loses alot of detail in comparison of the tri-lam. It sounds overly bright, harsh and muffled in comparison. Again, just my opinion. The differences are huge.
    The RTi4, RTi6, etc vs the RTi28, RTi38, etc -- The differences are the same as above. The new line comes back with the detail in the high end. Not as harsh, better mids/soundstage. Again, all my opinion.
    The RTi4, RTi6 line seems to trait back to the first RT line with the 3 and 5. With the Polymer tweeters. Which is no surprise as the new line uses Silk/Polymer.
    My favorite RT line by far is the first RT line, as I own the 5 and I like its sound pretty much over the rest.
    Just my take.
    Each line sounds different, for better or worse is up to you.
  • HBombToo
    edited March 2004
    You got that backward bucko.... I called Ken and ordered all my parts on Kens reccomendation thus Polk sent me 2 new tweeters and a crossovers for my pair of 55i's.
    I did not hear a HUGE difference PERIOD.
    Greg the cost benefit ratio is way low IMHO. BTW hows that SVS?:D If you posted somewhere I'm afraid I missed it.
    HBomb
    ***WAREMTAE***
    VR3 Posts: 29,441
    edited March 2004
    Well like I said, I thought it was something like that ;)
  • HBombToo
    edited March 2004
    I guess you have a case of dyslexia lately champ...
    HBomb
    ***WAREMTAE***
    VR3 Posts: 29,441
    edited March 2004
    well sheat the woofs ARE different... ---- One is Black, the Other is BLUE... ;)
  • HBombToo
    edited March 2004
    are you saying Polk ripped me off:confused:
    What is ya... Ignant:confused:
    HBomb
    ***WAREMTAE***
  • smglbrth
    smglbrth Posts: 1,496
    edited March 2004
    Well HBomb, like you said, one less thing to stress over. Are you still stressing over those "plastic thingy's"........:(
  • HBombToo
    edited March 2004
    No Sir:D I carefully removed them and cleaned all glue off. Then I bought a case af Armour All and gve them a good soaking. PERIOD :p
    1/4Twin
    ***WAREMTAE***
    VR3 Posts: 29,441
    edited March 2004
    GET ER DUN
  • gacole2000
    edited March 2004
    Henry,
    Loving the SVS! I just need to get rid of the wife for a day or so!
    Night and day from my old CT-100
    Thanks again- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • brody05
    brody05 Posts: 329
    edited May 2004
    Hi, I thought I would add my two cents as in the RT55 thread.
    I have a pair of RT2000i in the rear and also some RT55i's, I bought these at the time of the change over between the two 'series' and had both at home at the same time. I can say that there was a big difference, from memory the crossover freq was brought down in the RT..i range but I clearly remember that the rt..i series was much better in the imaging and soundstaging department, they really 'opened up' with the lower cross over frequency, but as I have always thought and said, if it sounds good to you that is all that matters. I hope this helps in some small way.
    Cheers
    Brody:)
