Center Channel Speaker...
Mike682
Mike682 Posts: 2,074
edited March 2004 in Speakers
I have a question regarding picking a center channel speaker. I have an H/K 225 and a pair of R30's. I am looking to buy a center channel and was wondering about picking the "correct" speaker to match the R30's. Polk's website says to use Csi 20/30, but I believe there is a new line out that replaced the Csi20's.
Also, what exactly does voice matching speakers mean? And do all the speakers have to be voice matched or can I mix brands?
As you can see, I am slowly buidling my system since money takes time to earn.....
Thanks for the help
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Post edited by Mike682 on
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2004
    Voice (timbre) matching is fairly important in home theater, although not mandatory. Basically you want your front three speakers to have the same tone. Imagine you are watching Gone in 60 Seconds, and a car drives from the right side of the screen to the left. As it does this, the sound emphasis goes from the right speaker, to the center, to the left speaker. You want the engine sound of the car to have the same tone across all three speakers. you dig?
    Regards,
    PolkThug
  • hoosier21
    hoosier21 Posts: 4,418
    edited March 2004
    I have a CSi20 for cheap, if you are interested let me know.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Mike682
    edited March 2004
    are there any specs that one can look at to see if a speaker is voice matched (sensitivity, freq response, etc) w/another speaker?
    hoosier, what are you asking for the csi20?
    Mains: polk R30
    Center: polk CSi3
  • hoosier21
    edited March 2004
    60.00 and shipping
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2004
    Originally posted by Mike682
    are there any specs that one can look at to see if a speaker is voice matched...
    For an absolute PERFECT match, all the speakers should be identical. Ie: Five RTi28's, Five R15's, etc etc.
    In my opinion, the key is to match the tweeters - which is usually easily accomplished by staying within the same 'line' of speakers.
    Some like to take it a step further, by making sure the midbass drivers on the speakers are identical also - but to me, that is a moot point - unless you use five IDENTICAL speakers.
    A change in cabinet size will change the overall Q of the driver, thus changing the tonal signature also. In a nutshell, even though a CSi40 uses the same mid-bass drivers found in, say, an RTi70, it is no more a perfect match than a CSi30 is. (same tweeter, smaller mid-bass drivers)
    Cheers,
    Russ
    Edit: The CSi20 will be a great match with your R series speakers.
