Carver C-9 Sonic Hologram Generator
Strong Bad
My mint Carver C-9 arrived yesterday via Fedex. I snagged this off the 'Bay for $90 (with shipping). Last night I gave it a quick low volume test and was very happy with what I heard. I have it mixed in with my (source order) Denon DVD2900, Dodd ELP tube preamp, Carver m1.5t amp and out to the Polk LSi25's. The C-9 is inserted at the Preamp out spot, then the C-9 goes into the amp.
I didn't change the angle of the speakers, even though the manual says to do so and will be testing further today with considerable more volume.
I like what i've heard so far! For those not familiar with it, the Carver Sonic Holography technology was their version of the SDA Technology from Polk. Where Carver did it electronically, Polk did it sonically with added drivers and special circuitry.
No excuses!
Post edited by Strong Bad on
Based on the gear that you are using,I'll bet it does sound pretty sweet.Congrats.JC approves....he told me so. (F-1 nut)
Strong Bad wrote: »For those not familiar with it, the Carver Sonic Holography technology was their version of the SDA Technology from Polk. Where Carver did it electronically, Polk did it sonically with added drivers and special circuitry.
Sonic Holography was my first venture into Stereo Dimensional effects and I loved it!! I still have a C-9 kicking around here somewhere. Great little unit. I have SDA's now and the two are not compatible (unless you like you sound really freaking weird) so the C-9 collects dust because I can't bring myself to sell it because of how much I loved it. ENJOY!!!SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Pretty much how Matt explained it to Bob once upon a time.... I've found the Sonic Hol sweet spot to be very narrow compared to SDA's. You?Strong Bad wrote: »Where Carver did it electronically, Polk did it sonically with added drivers and special circuitry.
Then there are those who have dared to use a C-9 to feed SDA's... Some report seeing God; others simply wet themselves.More later,
Tour...
Vox Copuli
The sweet spot only needs to be one person wide.
Using both results in nothing special aside from smearing and worse localisation of instruments. I don't recommend using both.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
First, when did you move to the UK?
Second, did my C-9/SDA comment really need a smiley?
Sez Lonesome George...George Grand wrote: »The sweet spot only needs to be one person wide.More later,
Tour...
Vox Copuli
If you set the speakers up properly, ie perfect triangle, the effect is much more pronounced.
were still talking audio,,right
JC approves....he told me so. (F-1 nut) -
george daniel wrote: »were still talking audio,,right
You guys are talking party. With only one chair in the room, I'm talking audio. -
Why would you even want the sweetspot to be more than one person wide? Why invite distractions?
The porch speakers by the pool are Sonic Hologram setup, not sure if anyone heard them since it rained for 2 days during PF2011.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I have to say after thoroughly testing the C-9 out with the LSi25's...WOW! The C-9 opened up the image and detail quite a bit. I did let it loose today with Dire Straits - Brothers in Arms SACD. Track 4 "Your Latest Trick" is very impressive! I'm very happy with what i'm hearing.
George and Troy...1 chair and the two channel rig in that room. Nothing else to screw it up or get in the way! The sweet spot is as wide as it needs to be.No excuses! -
The SDA tech provided a wider sweet spot, the Sonic Holography a more pronounced effect. Interesting info on both at:
http://www.thecarversite.com/yetanotherforum/default.aspx?g=posts&m=18282#post18282The web's most visited Carver audio forum: http://thecarversite.com
Carver mk II series audio amplifiers http://carvermk2.com
