Sda-srs interconnect cable
HERSHEY13
Looking for the interconnect cable for my SDA SRS speakers.
The cable to eliminate crosstalk. Lost it and need cable for proper canceling of crosstalk.
thanks
thanks
Post edited by HERSHEY13 on
Blade/blade?? Or pin blade??
Hello,i am also looking to buy a AI-1 interconnect for my SDA SRS blade blade.
I have just started within in the club even though i registered many years ago and i'm finding it hard to get around on here : ( -
There is not an AI-1 INTERCONNECT with a blade/blade as the SDA SRS cannot be run with a non - common ground amp..
Boo hoo...My dreams have been shattered :'( Thank you for this information ,much appreciated Toolforlifefan.
Now i need to find a good quality common ground amp .
Also need to get 10 posts up : ) cheers -
Hello TOOLFORLIFEFAN
It would be the pin/ blade type.
thanks for responding -
I have one if anybody needs it. It has some sort of rubber in the middle of the wire where it looks like it was spliced together somehow...Either way, works fine and I don't need it. PM me for details.
