audio connections questions
Dabutcher
Dabutcher Posts: 2,606
I have three new amps to my system and I was wondering about audio connections? I need to connect my two newer Marantz MA-700 monos and an Emotive xpa-3 I bought from the sale section of this sight.I am using monster speaker wire .And i wanted to upgrade my audio connections between marantz reciever and amps? I was looking on Accessoriesforless.com and saw IXOS brand and monster and ATS brands ? Would any of these be worth a try or do I need to spend Hundreds to get good sound? After all It is only copper wire right ? Also what is the difference between Audio connections and Video connections? As always thanks alot ... I finally made 100 posts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post edited by Dabutcher on
  • Face
    Face Posts: 14,340
    edited October 2011
    edited October 2011
    No, it's not only copper wire. Different flavors abound in cables. The signal cable link mentioned by Face is a good place to start, their Analog 2's to be exact is what I would aim at.
  • Dabutcher
    edited October 2011
    does Signalcable still give a Polk member discount? how much and how do i do it? Thanks,Darryl
  • djperez81
    djperez81 Posts: 388
    edited October 2011
    Yes i believe you do get a discount just let them know you are a member of the forum.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Dabutcher
    edited October 2011
    Thank you all again. Just ordered the three meter Analog II five cable set from Signal.as always ,thanks a lot! Darryl
    edited October 2011
    Good man, you'll be pretty happy with them, I gauraaantee. Man I miss that cajun chef,what was his name again ? My brain isn't functioning today, must have some whirlpool parts in there somewhere.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited October 2011
    Post 8 Laurel421 reported as spam for removal
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
