New to the forum and curious to see thoughts on external amps
jhkcam
jhkcam Posts: 11
edited October 2011 in Electronics
Hello all, I am glad to have found this forum! After 10 years, I finally decided to upgrade my home theater audio. I purchased a new Onkyo receiver and all new Polk speakers (models listed below). I love the way the RTi12's sound, especially for movies. The Onkyo puts out a pretty good amount of power, for a receiver. However, I can see where adding external amp(s) would be highly beneficial, especially for music.
I would love to get everyone's thoughts on the Emotiva amps, especially if you've had personal experience with them. They seem to be a very good amp, especially for the price. I have been looking the the XPA-2, XPA-3 and XPA-5 amps. I think that my DREAM setup would be to put the XPA-2 on the RTi12 lows and the XPA-3 on the RTi12 highs and also powering the Center. Any thoughts?
However, keeping $$ in mind, and having to convince the wife to let me buy more electronics :biggrin: I have looked at two other options. 1) Buying only the XPA-3 and driving the RTi12 lows and center channel and letting the Onkyo drive the RTi12 highs or 2) Buying the XPA-5 and bi-amping the RTi12 with 200 wpc to lows and highs and also the center channel. Again, I would love to hear any opinions!
Thanks all!
Video: Samsung UN55C8000
Audio: Onkyo TX-NR809 Receiver, Parasound 2250 2 Channel Amp, Polk RTi12 Fronts, Polk CSi A6 center, Polk RTi A3 surrounds, Infinity Alpha 1200S sub-1 and Rebuilt Infinity BU-150 sub-2
Post edited by jhkcam on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited October 2011
    You seem pretty set on emotiva ? Why choose emotiva ? Is it a price thing because there are way better amps on the used market that offer better quality .Is it the wattage rating that makes you choose emotiva because they have a very distorted sound once they get loud and can hiss like an angry cat .If its the warranty that makes you choose the brand then your going backwards in the quest for good audio .I bought an emotiva amp and when its paired up with some martin logans you can really tell the flaws in it .I also have polk rti8 and when you hook it up to the emotiva it makes them sound bright .
    The rti12's are good speakers and if you really want to enjoy them your cant go skimping on the amplification .Try somthing warm so that you can enjoy the 12's for music and movies .I would try out a sunfire grand 5 for $700 on audiogon as I have heard great things about them paired up with the rti's not to mention the sunfires never run outa power and dip lower than a big booty hoe at a hiphop club
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    Welcome to CP!
    There are mixed feelings here about the Emotiva name and their products. I have no personal experience though.
    About your bi-amping... thats a strange way to do it. Not sure if it will work efficiently. Let some other chime in. I would almost recommend you use the XPA-2 on your mains with something in place of the stock jumpers (Horrible). I think that would give you what you want with room yet. The XPA-3 would be great for rears and a center if it were my choice.
    I certainly don't agree with amping 1 pair of speakers and running the other off your AVR. I don't know enough about Onkyo to make that statement though.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    I'm certainly not set on a brand at this point.... just looking for options. I am pretty satisfied with the speakers now, so if I were to spend the money to upgrade, I would want a large increase sound quality. I would like to stay at $1000 budget which is why the Emotiva's looked quite attractive. And, the wattage certainly did play part in my initial search. If I spend money on an external amp, I definitely need to see a large jump in total wattage to the speaker b/c I know they need it....
    Drenis wrote: »
    Somewhere I heard that an ideal setup for these speakers would be around 200-250 for the woofers and 150 to 175 for the highs.... the Onkyo is rated at 135 per channel so I figured if I amped the woofers (lows) then the Onkyo may power the highs pretty well. I could be off, again, just my initial number crunching here :)
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    jhkcam wrote: »
    If it's crossed @ 80hz maybe... I have the RTi A9's myself, those woofers aren't sweating much with 200 wpc while in full range. I run a Carver TFM-42 on mine. 375 wpc RMS and headroom to 750 watts... That makes them sweat. When bass is turned up, it starves for power. So the point is that power should be relative to your needs. Especially if your running them in full range turned up.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited October 2011
    Welcome to Club Polk! You said it yourself - "They seem to be a very good amp, especially for the price." IMO, the only change I'd make to that would be to scratch out "very" - they are good, BUT if you're going after more than one, the price starts to add up. I had an XPA-2 and an XPA-3 - 5 channels of amplification for $1,500 at today's going prices. Really, there's so much more you can do with that money if you open your mind and are willing to look around and accept something that's not brand, spanking new. The cool thing about nice audio gear is that many of the people who own it take exceptionally good care of it!! I sold my Emotivas (thankfully, they seem to retain decent resale values) and replaced them with a single 5-channel amp - a "used" Adcom that no one would have been able to ever know it had been used. And then I had to figure out what to do with the remaining $700... :wink:
    My other suggestion? Forget bi-amping. Connect a single channel of any decent amp to each speaker, and while you're at it, go ahead and replace the stock jumper with some good quality speaker wire - DIY jumpers on the cheap. Given the gear you're working with, anything else is only going to be an infinitesimal improvement.
  • PSOVLSK
    PSOVLSK Posts: 5,371
    edited October 2011
    I run an XPA-5 and love it, but I have an LSi setup. I've heard many people say that the brightness of the Rti line and the brightness of the Emo are not a good match. No personal experience with an RTi/Emo setup though.
    mdaudioguy wrote: »
    I agree. If you drop a grand on an amp, let it power the speakers by itself.
  • stuwee
    stuwee Posts: 1,508
    edited October 2011
    Welcome to Club Polk jhkcam! I can't help with your Q, I never got into HT much, enjoy the forums :biggrin:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2011
    Welcome to Club Polk. Get a 5 channel XPA or other 200wpc amp, forget about biamping & be done with this particular upgrade. You can also check out Outlaw Audio for reasonably priced amps.
    Or if you're willing to shop used on Audiogon, you can check out Sunfire, Rotel, B&K, Adcom, Nad, etc.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    Thanks, you all have given me a lot to think about here and more options to check on. In just trying to learn this stuff though, I am still trying to figure out why I wouldn't want to use 4 of the 5 channels on the fronts if I were to get a 5 channel amp. For example, if I got an amp that was 200 x 5 for example, If I bi-amp, I should be getting 400 watts total to each front as opposed to 200 to each front using a jumper correct? The external amp would still be pushing the fronts by itself, just using 4 of the 5 channels and double the power instead of 2 of the 5 channels running a jumper.
    Again, just trying to understand this concept... thanks!
    Edit: 400 watts total to each front bi-amping in my example not wpc...
    Trying to figure out why I wouldn't bi-amp the highs and lows i guess.... I'm running a 7.1 receiver as a 5.1 b/c I'm already bi-amping the speakers from the receiver (135x2 to each speaker in stereo). Why wouldn't I do the same with an external amp...
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    Biamping doesn't allow you to add watts. It is designed to allow you to run an active crossover between your avr and external amplifiers. That way you can control which frequencies go to which half of the speaker. It also keeps you from sending amplified highs in to the woofers and amplified lows in to the tweeter section.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • nwohlford
    nwohlford Posts: 700
    edited October 2011
    When done correctly (remove crossovers in the speakers and crossover prior to amplification), biamping does reduce the likelihood of clipping (isolated clipping can occur even at moderate volume settings when a lot of sounds occur at once) . For instance, if you use 200 Watt amplifiers for both the low and high frequencies of the speaker, then you have 200 Watts available separately for the low and high frequencies. For simplicity sake, say you would experience clipping at 200 Watts, then with biamping you would experience clipping only if the low frequencies or high frequencies are individually greater than 200 Watts (with one amp you would get clipping if the total of the high plus low frequencies were greater than 200 Watts). You have not increased the gain of the amplification, so for the same volume setting, it will have the "loudness" as using one amp (minus any effects of clipping).
    Now if you do not remove the crossovers in the speakers and still "biamp", then what is below the high pass for the high frequency section of the speakers and what is above the low pass for the low frequency section of the speakers still has to be created by the amplifiers and will be used up by resistors in the crossover circuits. Thus you have not really reduced the strain on the amplifier (the true purpose of biamping). In the case of an AVR (with some exceptions), you are actually increasing a strain on the amplifiers' power supply by adding extra channels and doing more harm than good. Unless you have mono block amps, you would usually see better results by leaving the additional channels unused (even with mono block amps any benefit is questionable).
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2011
    Welcome to Club Polk jhkcam! :biggrin:
    Since Emotiva generates a lot of animosity here I will not waste much time commenting except to point out that ideally a good demo is the best way to get the sound you like and unfortunately you can not really do that with Emo.
    First, I wouldn't waste any time with bi-amping. As pointed out, the main goal of bi-amping is to isolate the high and mid more than anything else. When you bi-amp for power purpose, you need matching amps for best results.
    In HT, you want to focus on your front stage and keep everything in balance (matching speakers, matching amps) so, when all considered a 3 channel external amp would be ideal to power your fronts and center equally. As far as your rear you can power them with your Onkyo without any issues as first the unused power from the front stage will be available for your rears and second even if that wasn't the case you have to realize the rear do not require as much power as the front stage in an HT set-up. Do not focus so much on watts but ratter on the SQ. BTW; always keep in mind that in order to make a real difference you must double the power. However, having an external amp for your front stage gives a break to your Onkyo (Onkyo are usually hotter than most receivers), provides for cleaner power all around and more likely would allow for better SQ.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • michael1947
    michael1947 Posts: 775
    edited October 2011
    Hello to all. I have been reading for nearly a year on this forum and have learned much...However...I have been fiddling around with hi-fi for more than a half century and in spite of what I have read in the above exchange I do not understand the bi-amping thing. My old stuff say my JBL's 4411's and L19's have only two hook-ups for speaker wire and sound quite nice with my old Kenwood's or Yamaha. I have a Klipsch setup in one room for HT however they also are single hook-ups and the system is also quite good. I have a newer set-up in my basement workout room with a Yamaha rxv 2700 with most of the dsp options and a variety of Polk speakers...and it sounds unbelievable. The difference a few decades can make. For speakers on the rxv 2700 are the newer monitor series polks: M70's, CS2's and M40's but i have two pairs of rt2000p's that I may like to put into the mix. I believe most of these speakers mentioned have dual hook-up's. Nothing is bi-amped. Now, I have 3 old Kenwood 150 wpc amps, two in use and a spare so my question is could I use a couple of my old Kennys to by-amp something. Also, what is the reason for all of the increased power. My JBL's are run by an old time Yamaha CA1010 and a DVD player and puts out around 100 wpc with just about perfect sound and the volume knob does not even approach 1/2 way. One of my Kennys runs my SDA 1A's and more power would be criminal. I run sub's on my two HT systems which should take some of the pressure off the receiver so where does all of the additional power come into play. Won't it just be louder. I apologize for running on here so if you have any words of wisdom "I am all ears."
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited October 2011
    Hi Michael1947,
    Welcome to the CP Forum. Using two or more amplifiers to provide power for a single speaker system has been discussed quite a bit here and elsewhere, but let me see if I can give an opinion. There is "Bi-wire" with a capital "B" where there is no internal crossover used inside the speaker and all of the frequency shaping is done externally between the preamp stage and the amplification stages. There are many who feel that this is the only true way to bi-amplify and anything else is a waste of effort. Then there is "bi-wire" with a lower case "b" where the speaker's internal crossover is maintained and two individual amplifiers power the two "halves" of the speaker.
    In Bi-amping a speaker the owner has to find a suitable external electronic crossover that provided sufficient adjustment capability to re-establish the proper blending of what the speaker's designer originally had in mind. At one time there were lots of companies that made these kinds of products, in fact the annual Audio Equipment Directory had a category just for them. Companies such as Audio Research made two, both vacuum tube based. But no longer, I can only think of Marchand off of the top of my head. The idea was that if you could do the frequency shaping before the amplification the communication path between amp and speaker tweeter or driver would be more perfect. Instead of large coils and bulky capacitors smaller line level, active circuitry could be used with less change to the integrity of the sound signal.
    But, does this necessarily mean that "bi-amping" is to be not considered, not necessarily. One possible improvement could be the use of different connecting wires between the different amplifiers and the different sections of the speakers. One theory has it that when dealing with frequencies below around 600Hz it is the total series resistance of the speaker wire that is most important. With frequencies above 600Hz it is the series inductance that might make the sonic difference. If you are bi-amping you are free to experiment with connecting wire designs to maximize the sound performance, a thicker less resistant wire for the amp-to-woofer/mid range part of the speaker. And a smaller gauge solid core wire for the amp-to-tweeter part of the speaker.
    Also some are of the opinion that different amplifiers have different sonic characteristics that lend them to different aspects of sound quality. A classic example is the excellent sounding Adcom GFA-535, the lower powered version of the GFA-555. Most feel that the 535 produces wonderful high frequency transient detail and lack of "hardness" or brittle quality. The 555, on the other hand, represents the kind of woofer control and dynamic range that can bring a speaker alive. Use a specific amplifier for its sound character, maybe solid state and vacuum tube blending? But, keep in mind both amplifiers need to have the same input sensitivity or one of them has to has some way of adjusting its output level to get everything balanced.
    If you have two amplifiers available, try using them both and experiment with different speaker wires to see how you can change the sound character. As a test try some 300 Ohm twin lead solid core antenna wire on the treble amplifier and a thicker wire for the lower range. I hope this has been helpful.
    Regards, Ken
  • mole'
    mole' Posts: 3,160
    edited October 2011
    i have a XPA-3 and have used it with my RTi10 and LSi15 and loved the way it sounded. before i picked the EMO amp up i say that EMO stuff is not really liked over here......
    you can get a new amp from EMO and test it out. if you dont like it, send it back....but try different things / setups is the beauty of this hobby.....
    mole'
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    I am not a fan of Emotiva personally but I am especially not a fan of emo and the RTi series combined. That has the making of a harsh sounding system to me. There is nothing wrong with Emotiva other than the fact that they can get kinda brittle when you start really using the volume. For most people this isn't an issue but I like a more balenced and mellow sound. Even for HT.
    The RTi series is a bit bright to begin with so I would shoot for something warmer like B&K or Rotel before Emotiva.
  • jbooker82
    edited October 2011
    I was also told parasound, and carver sound warm.
    My 250 wpc A-753x 3 channel carver amp is a real nice paired with my RTI A7's and CSI A4
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    ^ This.
    I love how my RTi A9's sound with my Carver.
  • jbooker82
    edited October 2011
    There is an A-753x on ebay now. No one has bid on it yet. $599 but it looks rough. If it works fine, nothing a can of black paint cant fix, expecially the top vented cover. The face doesnt look to bad.
    Plus you have to love those 3 old school VU meters.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    Aahhh, thanks guys! I believe that a light just went on. :cheesygrin: So when bi-amping (passive) you're not actually doubling the power, because each output channel from the receiver/amp reproduces the full sound spectrum. Therefore, without an external crossover, you don't really see much true gain (especially not double) because each component of the speaker will only reproduce the frequencies of which the internal speaker crossovers are set at anyway..... (I believe, if I'm following correctly ?)
    -Justin
  • cfrizz
    edited October 2011
  • deronb1
    deronb1 Posts: 5,021
    edited October 2011
    Holy Moly! I thought I wrote this post! I have the exact same issues as you and after a couple of months of messing around with a similar set up as yours, here is what I have learned.....
    RTi12s need A LOT of power. That said, they can run adequately on 100wpc or so from a decent AVR, especially for HT. But in order to get the low end punch that they are capable of, you need more wattage.
    I have a Pioneer Elite VSX-23 (110wpc) and also picked up a cheap Kenwood 150wpc amp. I have listened to the 12s using just the AVR, just the amp and also "bi-amped" with the Pioneer running the tops and the Kenwood running the bottoms.
    The best performance hands down is with it bi-amped. Now, if you are looking at a 200wpc plus amp, that may be a different story, I have not listened to them with that much power out of one amp, but I am telling you from my experience that bi-amping DOES make a difference with these speakers.
    The low end on these are subs, pure and simple. The "sound" comes from the tops and of course, need to be adequately powered. The bottoms need umph and adding a seperate amp to them will do that. Since the xover on the bottoms is less than 120HZ, I wouldn't get all caught up in spending a ton of money powering them with some fancy schmancy amp. Find some cheap clean power, at least 150wpc, and let er rip!
  • jbooker82
    edited October 2011
    I would find a good quality used amp and run the entire speaker off of it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • NewHTguy
    NewHTguy Posts: 584
    edited October 2011
    I would buy the best two-channel amp you can afford. Your Onk has plenty of power for a center and 2 (or 4) surrounds. Put the money where it is most needed. That way you have a great stereo system and great HT.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Willow
    Willow Posts: 11,215
    edited October 2011
    NewHTguy wrote: »
    I would say that a 3ch is a min. requirement. That way the whole front stage has the same amount of power where it needs to be.
    EndersShadow Posts: 17,687
    edited October 2011
    Willow wrote: »
    I agree with the above, you want your front soundstage to match power wise. HOWEVER, I also have my LSi 15's what I call "ghetto bi-amped". The Integra I have (like the Onkyo's) allows you to set the AVR to bi-amp in the menu and then sends the full signal for the high's and lows out via the fronts and rear surrounds.
    What I did is to use that setting in the AVR and then connect those 5 pre-outs (2 per L/R + 1 for center) to my Carver AV-705x amp. I call it "ghetto bi-amping" since there is no EQ between the AVR and the amp so each set of interconnects are passing the full signal to my amp. According to a couple folks on the Carver forum, my amp is like 5 monoblocks in one chassis, they just all draw from the same power supply however. So while its not true bi-amping as the L/R highs and lows are on the same amp, the power draw doesnt overwhelm the amp by any means.
    I found this makes things a little bit clearer at low levels, and gives me more punch. I have heard from others that have done similar that the differences continue as you crank it, but personally I havent experienced that since I live in an apartment and cant go hardcore on the volume knob. Plus I figure my 8 ohm surrounds are more than easy enough for the AVR to handle.
    I dont think every 5 channel should be used like I am using mine however.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    Well, after hearing all the input and a lot of browsing, I made the decision to go with a Parasound 2250. Hopefully I will be happy with it... Looking forward to seeing what it will sound like on the RTi12's! Thanks again for all the input.
    -Justin
  • NewHTguy
    NewHTguy Posts: 584
    edited October 2011
    Congrats, I drove Rti10s with my Parasound 2250 before I switched to Lsi25s. I also had a Csi5 being driven by my Onk, which never seemed underpowered. The 2250 runs fairly cool (can't say that for Onkyos) and gave detail to my Rti10s that the Onk could not match. My wife and I heard flaws in CDs that we had never heard before. Listening to Tori Amos, I could hear each strike of the keys on her piano. Report back and let us know how you like it!
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2011
    It'll go out tomorrow Justin, so hopefully this time next week you'll be able to report back :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    PrazVT wrote: »
    Absolutely... looking forward to it. Thanks Prashant!
