My Teac X2000R was adjusted and updated by Ken Swauger
schwarcw
schwarcw Posts: 7,357
edited October 2011 in 2 Channel Audio
Greetings!
My Teac X2000R has always been one of the nicest looking and sounding pieces in my audio system. I am a little anal about having this sophisticated machine in the best possible working condition. I gave it to Ken at the DC Audiofest in July. Ken does some really nice repair and resoration service to reel to reel machines. Check out his website Here
Ken checkedd over the machine, lever tension, tape path alignment, checked the record and playback response (provided a nice hand drawn graph), head alignment, etc. He also changed the light bulbs from the white candescent to the Blue LED type. The machine has never sounded or looked better!
If you are interested in reel to reel, Ken is definately our resident expert! Thank you Ken for the super job!
How about a little RTR pie?:smile:
Carl
Post edited by schwarcw on
    SCompRacer Posts: 9,078
    edited October 2011
    Awesome R2R Carl! I'm in major lust mode! Love the Blue LED's. High marks to Ken for the TLC!
  • headrott
    headrott Posts: 5,496
    edited October 2011
    Did Ken add the wood paneling on the outside of the case? Looks nice. I like the blue LED look. I may have to add some to my X-2000R. Good idea on Ken's part.:smile:
    Greg
  • george daniel
    george daniel Posts: 12,096
    edited October 2011
    absolutely gorgeous.
  • janmike
    janmike Posts: 6,146
    edited October 2011
    Very nice looking piece of gear Carl.
    Michael ;)
    NORTH of 60°
  • stuwee
    stuwee Posts: 1,508
    edited October 2011
    w00t! w00t!! Love it! Very sharp with the blue, and that wood cab is beyond nice. Ken does great work! I'd love to have him refurb my lowly A-3340 :smile:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • dkg999
    dkg999 Posts: 5,647
    edited October 2011
    Ken is da'bomb! That is one sweet looking R2R deck.
    DKG999
  • schwarcw
    edited October 2011
    Thanks for the kind words folks! The veneer was done by me. F1Nut gave me some excellent pointers on finishing. I used a wood dye instead of a stain. I also used some hand wiped polyurathane. The depth in the wood grain is just amazing.
    Ripping lps to tape is easy LOL!
    Carl
  • schwarcw
    edited October 2011
    Stu, the 3340 is a very nice machine! It should serve you well!
    Carl
    tonyb Posts: 33,065
    edited October 2011
    SCompRacer wrote: »
    Amen to that Rich, Ken is the man. That R2R is just frickin' ourstanding.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited October 2011
    Ah, the X-2000R was a pleasure to work on, like tuning up a 911 that has been lovingly preserved. I kept looking for an area where I could whip out the Flitz, but Carl had already been there.
    Now, this one is the complete opposite. It is without a doubt the most messed up A77 I've worked on. It must have been used in a coal mine office or someplace grimy. I've had to take it apart down to the frame and scrub each and every part with a toothbrush and Soft Scrub. But, I think the motors are fine, I don't hear much bearing noise.
  • schwarcw
    edited October 2011
    Greetings Ken!
    Please put on a dust mask while cleaning that thing. Who knows what could be in that dirt. Seriously, there could be asbestos in there, mold, or the Andromeda Strain.
    I know once your finished with the refurb it will look like a museum piece and sound like a Stratavarius.
    Carl
  • [Deleted User]
    edited October 2011
    Thanks for the reminder to use a mask, you're right about not wanting to breathe any of that gunk in. Most of the insulated cables that come from the AC interlock and the motors are gummy, probably some of the plastic's elastomer material leaching out. So I'm used to having to get rid of that sticky mess, but in this case these cables now have another coating of black grime on top of the gummy undercoating. I start off with GooGone on a cotton ball just wiping it off, stubborn gunk needs acetone and a Q-tip. But I've never had to scrub parts with a toothbrush and Soft Scrub before.
    But, it's very satisfying to see the rinse water take all the grey gunk away and the original finish start to come through. And then you spin the outer motor housing and hold it up to your ear and only hear a very slight whirring sound with no bearing chatter and can't believe it still sounds so smooth. The motor run caps are all well within specs and have low ESR and should be fine. The stainless steel faceplate is shot, but I very carefully puled it away from the stock plastic faceplate and it looks brand new. I've already found a lower faceplate that is in pretty nice shape and two wood cabinets to work with. I just have to remove the head block assembly, upper input/output assembly and pinch roller arm assembly and I'll be down to the frame. Good feeling!
    Anybody watch that cable show about the guys who refurbish old Coke signs and candy machines? I love it, can't get enough.
    heiney9 Posts: 25,396
    edited October 2011
    Very NICE Carl!! What sweet piece of electronics. As I understand it, Ken is about the best there is for this kind of work. Meticulous, methodical and he seems to love doing this kind of work.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2011
    Great team work, cudos to KS for the restoring job, cudos to you for the beautifull finish work and of course cudos to F1 for his assistance for the finish supply. This reel to reel is a real beauty! :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
