denon 2311 or pioneer vsx 1121 help please
AndrewReefer559
AndrewReefer559 Posts: 28
edited October 2011 in Electronics
looking at these 2 receivers. The 1121 is now 499 on new egg, so im somewhat sold on this unit already ha! then why post? i have a few questions. Is the denon going to be more powerful? Is there any difference in visual qualities between these units? My local CL has a denon 2309 for 300, looks good doesnt have airplay or 3d but not a huge deal, any input?
thanks
Post edited by AndrewReefer559 on
  • evhudsons
    evhudsons Posts: 1,175
    edited October 2011
    I can't say anything about the Denon other than I know they are well regarded. I have the Pioneer vsx-1120, and am very happy with it. If it had been in the budget or had known about 2 channel setups, I would have gotten an elite with a preout to hook up to another amp. But for me that is down the road anyway. The calibration mic works much better than I had imagined, although you will wind up changing it to your liking. It is very versatile, and the owner's manual is a book.
    I would say if they are basically identical for what your needs are, I would go with more power.
  • DON73
    DON73 Posts: 516
    edited October 2011
    I have the 1121 and I'm using an Adcom 150 watt amp for the front speakers and the Pioneer amps for the center and surrounds. On screen setup was fairly easy but some of the print in the manual should be much darker for easy reading. I used the auto audio setup but I had to change every setting to suit my room and speakers. I paid $499 from Amazon with free shipping. Ordered one day received the next for an added $3.99.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • AndrewReefer559
    edited October 2011
    should i be worried about the price drops on the 1121 lately? I just dont want to sacrifice any video quality by deciding one brand or another. I heard the denons use dedicated amps per channel as opposed to pioneers 1 large amp broken down?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2011
    If you like an used receiver, I would get at higher receiver model that has pre amps outputs. You could save some cash later.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    thanks
    According to recent tests by Home Theater Magazine this is the tested power into 5-channels at .1 distortion:
    Denon 2311 - 83 watts
    Pioneer 1021 - 46 watts (sorry, don't have the 1121 numbers)
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • AndrewReefer559
    edited October 2011
    wow marty thanks for those #'s
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    Glad I could help. There seems to be an obsession with "watts" on most forums so when I see test results I usually write them down. I realize they may not have anything to do with sound quality and certainly don't really speak to features, price, etc. Generalizations are dangerous but I have noticed an emerging trend in the 15 reviews from this past year.
    It seems that NAD. Cambridge, Arcam, and Pioneer Elite usually give you more into 5-channels; Sony, Denon, Integra, and Onkyo (very model dependant) get somewhat close (80% range); and Marantz (73%), Pioneer, and Yamaha bring up the rear. Of course if you're using external amps I guess it doesn't matter.
    TT = Audio Technica
  • rebuy
    rebuy Posts: 695
    edited October 2011
    I think H-K would fall into the first group as far as power goes.
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    rebuy wrote: »
    Sorry, I should have included HK in the first group (forgot, Duh). You don't usually get too much more like with NAD, Cambridge, and Arcam but you definitely get what was advertised into all channels driven. My mistake, although there aren't many reviews of HK that appear in the press.
    TT = Audio Technica
