Replacement for RS SPL meter?
[Deleted User]
[Deleted User] Posts: 7,658
edited October 2011 in Electronics
CP Folks,
Anybody aware of a good quality, moderate cost replacement for the trusty RS meter? They seem to be discontinued and in very short supply.
Thanks, Ken
    mhardy6647 Posts: 34,913
    edited September 2011
    Do you want/need an R/S meter? I have a spare (analog) one - PM me if you're interested.
    PartsExpress and MCM both, I believe, do have inexpensive (as well as expensive) SPL meters - check their websites.
    I cannot say anything about their quality, though.
  • jbooker82
    jbooker82 Posts: 1,627
    There are some other ones that look exactly like the RS units. I am sure they are made by the same company that made the RS ones.
    You can also find people selling them on ebay. Do an ebay search for the radio shack part number only. You might call radioshack and have them look to see if there is any stores near buy that would happen to have one as well.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Drenis
    Drenis Posts: 2,871
    Ken,
    PM rooftop59 and ask him. I just bought one from him and he had mentioned that he had two. Not sure if he still has it but if it helps.
  • [Deleted User]
    edited October 2011
    Thanks guys, actually I have one and it's fine. I'm helping Polk out by going over their web site's "advice" and "FAQ" sections, updating them and making sure everything is accurate. One of the articles, written by Paul D., referenced the RS meter. I've checked on their site and they don't seem to mention either the analogue or digital versions any more. A few Google hits about an Asian made meter, but it doesn't look as good as the RS.
    Cheers, ken
  • Emlyn
    Emlyn Posts: 4,620
    edited October 2011
    There are many "SPL meters" listed on Amazon that are designed for industrial and environmental use but they can be used for audio system testing as well. For audio use, getting one with "C weighting" is necessary. Some meters only have an A weighting setting. Radio Shack sold both analog and digital meters a few years ago and I picked an analog meter at the time based on advice that the digital meter of that time wasn't worth the extra money. There are at least a couple of companies marketing an analog meter that looks identical in function to the Radio Shack analog meter, but the prices are much higher than they used to be. If I was going to get a new one, I'd probably get a digital meter since there doesn't seem to be much of a price difference between them and analog anymore.
    http://en.wikipedia.org/wiki/A-weighting
  • mantis
    mantis Posts: 17,312
    edited October 2011
    I own a few Radio Shack version Analog and digital as well as the Nady Model. The Nady is identical in every way except the name. They are both made by the same company or cloned very well.
    Dan
  • Emlyn
    Emlyn Posts: 4,620
    edited October 2011
    Thanks for confirming that on the Nady model, Dan. Looks like they just jazzed it up with some yellow plastic instead of black plastic. The analog meters should last a long long time because they are so simple in function.
  • [Deleted User]
    edited October 2011
    Perfect, that's exactly what I needed!
  • [Deleted User]
    [Deleted User] Posts: 1,225
    edited October 2011
    and just who is this "Paul D." you speak of ?????
  • [Deleted User]
    edited October 2011
    That would be "Polk" Paul, aka Paul DiComo.
  • skrol
    skrol Posts: 3,437
    edited October 2011
    "Nandy", would that be a knock-off "Tandy" aka Radio Shack?
    Stan
    Main 2ch:
    HT:
    Other stuff:
