Bi-wre vs Quality Jumpers
cokewithvanilla
cokewithvanilla Posts: 1,777
edited September 2011 in 2 Channel Audio
I am trying to prepare the Sequels for the new panels. The current 11.5ga jumpers are quite a mess. I figure that I have two options: replace them with quality spade/spade jumpers or get another set of matching wires (those MIT ones from the b stock sale).
My amp, the 5800, has 2 sets of binding posts per speaker so I can reasonably bi-wire. Anyone have experience with this?
Post edited by cokewithvanilla on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    How much was the new panels ?
    EndersShadow Posts: 17,687
    I would go with the jumpers myself. I believe Russman had a deal where you donated some money to a fun and some guy made you a set of his jumpers.
    If not Audioquest sells them for a decent price, or you can make your own using whatever cable and plugs you want.
    Its easier to hide one length of wire rather than two.
    What I did myself was to get a set of 14/4 Audioquest FLX wire so I can bi-amp or bi-wire my fronts with the same wire.
  • cokewithvanilla
    I am talking from a sq perspective only. I can get matching wire for $50, or jumpers for nearly the same price. I don't hide my wires, so this isn't a concern.
    SCompRacer Posts: 9,078
    You will get various opinions on bi-wiring any type of speaker, even at the ML forum regarding your specific ESL speakers. Some folks bi-wire just to eliminate poor quality jumpers. Some folks use different wire for the highs and lows, claiming a difference. Speaker cables are sold with internal (one termination) and external (two terminations) bi-wire capability. Some say it depends on the amp.
    I've only had one passive ESL speaker here, and couldn't tell a difference when horizontal bi-amping it with two SS amps (never tried bi-wiring one amp). Again, with ESL's it depends on the amp as the panels present a capacitive load to deal with. Same amp bi-wired, the amp deals with the same capacitive load.
  • zingo
    zingo Posts: 11,258
    I prefer jumpers as it's cleaner, and you only have to run one length of wire. The way I used to do it was banana jumpers into the top of the binding posts, and then spade speaker cables that connected to the bottom.
    I probably still have some 12AWG jumpers with cheap bananas if you want me to send them to you. They are nothing fancy, but a fair amount of copper for a solid connection.
  • cokewithvanilla
    zingo wrote: »
    Thanks for the offer. However, my speaker cables are banana plugs. This makes it so I need spade jumpers. My panels are coming in sometime this week (according to ML), so I might just have to use what I've got for a while.
