Polk Audio Rti4
SjN
SjN Posts: 1
edited September 2011 in Speakers
Hello,
I currently have Polk Audio rti4 speakers hooked up to a YAMAHA HTR-5920 Receiver. I mainly use these speakers to listen to music, all kinda music (POP, ROCK, Classical, etc)
I've been wondering if upgrading the receiver would improve sound quality?
Also, I don't know how relevant it is to this forum, but, I have the receiver connected to my desktop's soundcard using this type of wire:
http://www.vosonic.com/upload/product_related/1_14_large.jpg
So I was also wondering if having this kind of setup would have any negative affect on the sound quality?
(Not that I am having any problems with the sound right now, I am just looking for ways to improve it. I am not an expert in those things, so I can't really tell if the way my speakers sound right now is good enough, I only know that it's not bad.)
So any advice would be appreciated! Thanks in advance.
Post edited by SjN on
  • stangjason
    stangjason Posts: 341
    I've always read that Yamaha + Polk RTI speakers = overly bright sound. If you want a good match for music you should go with a 2 channel Harman Kardon receiver
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
    Alittle more info is needed here. Do you plan on just using it for 2 channel, or do you think you will also go for surround sound in the future ? Do you have a budget ? A seperate pre amp+ amp combo for 2 channel is the way to go. Also, for music from a computer, without an outboard dac, your spinning your wheels to get good sound just piped into a receiver. Just sayin' is all, you may be happy with it, i dunno.
  • B Run
    B Run Posts: 1,888
    I personally didn't like the sound of my Rti's with my Yamaha rxv-1800 for music, but it sounded good for HT. I think you can always improve sound though:wink:
  • thesurfer
    thesurfer Posts: 574
    stangjason wrote: »
    I strongly 2nd, that, i use a H/K, for my 2 channel, clean, accurate and warm sound,
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
  • rebuy
    rebuy Posts: 694
    So you have a H-K and a yammie? You haven't tried the H-K yet?
    Get with it and do your own test.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    SjN wrote: »
    Hello,
    Your current avr seems to be an 'entry' level - not that means it is 'bad', but yeah, you probably could get better sound out of your RTi4s with a better AVR.
    Not to poo-poo what others have said, but not all Yamaha AVRs are 'bright'. I actually started with RTi4s and a Yamaha RX-V1800 and I wouldn't characterize it as bright - even the reviews of this particular unit were characterized as 'warm'. I can't speak to the other Yamaha avrs, maybe they are 'bright' compared to other brands or models.
    Other opinions may vary - all good - that's what makes first hand ears on experience a must in this hobby.
    Maybe 'bright' is a personal preference and is not a bad thing - depends on what you like to listen to and how.
    Anyhoo....yes - everything matters - a better AVR would be a sonic step up.
    Maybe consider a Marantz SR6005/6 - might be a good match for the RTi4s - and you could then decide to upgrade your speakers later, or add an external amp.
  • thesurfer
    Erik Tracy wrote: »
    A Marantz?? Erik, i thought they stoped making those long ago?
  • Erik Tracy
    thesurfer wrote: »
    Sure - Marantz makes current AVRs - some have gotten some vg reviews.:smile:
