Akai sa-2600
JimBRICK
Hi Guys I just picked up this amp on the cheap ($20) and all lights are turning on but I'm getting no sound. There are settings on the rear
which I've never seen before. Anyone know what I should have these setting at?
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
That picture is a bit too small I'm afraid... can you attach something larger?
Could we see a front and back on that. I can't find this on google.
The integrated amp AM-2600 is there but no SA?
Is this a receiver or integrated?
Does it have pre-outs. Some receivers have a switch the enables or disables the pre-outs on the back?
Or it may be missing jumpers for the in/out pres if it doesn't have internal connections?
Did you hear the speaker 'relays' click a few seconds after you powered up. That's a good sign if you did!
AM-2600 sorry, I will take a pic when I get home. I'm hoping its just settings and not something blown inside2 CHANNEL
Under construction -
this is the front2 CHANNEL
That's the integrated AM 2600. There is some info on Audiokarma about that unit you might want to do a search there.
That's got to have pre-outs. Can we get a large back shot?
As soon as I get home from work I'll take a picture. I'm thinking something might be wrong inside. I hope not cause it looks killer with my old OHM speakers I have them hooked into2 CHANNEL
The settings on the back are for the Phono 2 stage i believe. Although the back of yours looks different from anything else I have seen.
Where are the speaker connections? -
in the rear top. there is A and B speakers. Big push pin locks2 CHANNEL
Under construction
