Akai sa-2600
JimBRICK
JimBRICK Posts: 1,543
edited September 2011 in Electronics
Hi Guys I just picked up this amp on the cheap ($20) and all lights are turning on but I'm getting no sound. There are settings on the rear
images?q=tbn:ANd9GcSY9BwfpAALfqIu0Z8lbMZe9ZaHVyHRqItKC9Wpoc7vwktkI5o7rSa_AQM
which I've never seen before. Anyone know what I should have these setting at?
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • Drenis
    Drenis Posts: 2,871
    That picture is a bit too small I'm afraid... can you attach something larger?
    Could we see a front and back on that. I can't find this on google.
    The integrated amp AM-2600 is there but no SA?
    Is this a receiver or integrated?
    Does it have pre-outs. Some receivers have a switch the enables or disables the pre-outs on the back?
    Or it may be missing jumpers for the in/out pres if it doesn't have internal connections?
    Did you hear the speaker 'relays' click a few seconds after you powered up. That's a good sign if you did!
    cnh
  • JimBRICK
    AM-2600 sorry, I will take a pic when I get home. I'm hoping its just settings and not something blown inside
    2 CHANNEL
    Under construction
  • JimBRICK
    this is the front
    2 CHANNEL
    Under construction
    That's the integrated AM 2600. There is some info on Audiokarma about that unit you might want to do a search there.
    That's got to have pre-outs. Can we get a large back shot?
    cnh
  • JimBRICK
    As soon as I get home from work I'll take a picture. I'm thinking something might be wrong inside. I hope not cause it looks killer with my old OHM speakers I have them hooked into
    2 CHANNEL
    Under construction
  • Joe08867
    Joe08867 Posts: 3,919
    The settings on the back are for the Phono 2 stage i believe. Although the back of yours looks different from anything else I have seen.
    Where are the speaker connections?
  • JimBRICK
    in the rear top. there is A and B speakers. Big push pin locks
    2 CHANNEL
    Under construction
