Omega Hoyt Bedford Type 1 full range (TAMPA)
doctorcilantro
doctorcilantro Posts: 2,028
edited September 2011 in For Sale (FS) Classifieds
$540 pickup.
STANDS NOT FOR SALE
Come with foam port plugs.
All are like new condition with at most, some fingerprints; meticulously cared for. HB's are only 6 months old. Liquidating my entire HiFi right now or else I would keep them.
(2) Omega Hoyt Bedford Cherry 8″ 98db/w full-range single driver
They have magnetic grills which I will take a photo of. Have original boxes for all. Immaculate condition.
"This is an all new driver. It?s an 8″ dual cone and shares the whizzer from the ALN8Omega Alnico driver.
Ferrite motor with wood damping cover.
Extremely fast and articulate.
97dB efficiency
8 Ohm impedance
Type 1 features
Designed and built in house.
3/4″ soft wood MDF for stability and 1/4″ Hardwood MDF lamination on front and back
Ladder bracing with rear wall diffuser
Omega damping throughout.
Inset driver and attached with 8 brass machine screws and zinc inserts.
3″ flared Prescision Port.
System can be run sealed or vented.
Vampire multiway binding posts
Triple lead internal wiring. 2 positive and 1 negative
Best quality wood veneers used on all panels.
Phenolic sheet between MDF and Veneer
Magnet Grills.
10 Year warranty.
Size: 23″ Tall x 11″ Wide x 11.5″ Deep"
index.php?action=gallery;sa=view;id=53961
index.php?action=gallery;sa=view;id=53965
index.php?action=gallery;sa=view;id=53966
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Post edited by doctorcilantro on
    pitdogg2 Posts: 27,333
    what benefit does 2 postive wires bring to the table?
  • doctorcilantro
    I did that with my last set of Omegas, seemed to tighten up bass and provide a touch more clarity and presence overall, and I believe Louis does use two runs internally. He doesn't offer an explanation, but only that it sounds better to him.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    wow that is strange except that I'm a big wire overkill kinda guy, so thats was what i was thinking. Nobody ever tried just one larger wire gauge to see?
    by the way those look very nice GLWS.
