Speakers for 6700
I am buying 6700's this week and have the choice between
these two receivers
Yamaha RX - V440
or
JVC RX-8030VBK
Which one is more compatible with the 6700's and the 303 subwoofer?
these two receivers
Yamaha RX - V440
or
JVC RX-8030VBK
Post edited by bsand on
Both are probably fine receivers, but I'd go for the Yamaha. I've owned both brands, and both are reliable and full of features, but I am still amazed by the sound and dynamics of my Yamaha.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Polk PSW-350 Sub -in storage.
Yamaha RX-V681 A/V Reciever
Sony SCD-CE595 SACD Player -
Thanks for your input. Is the Yamaha also better for music cd's?
Brahm -
Only you can determine which sounds "better", but I would say definitely so. There are many highly respected receiver makers out there and Yamaha is certinally one of them.
I find it unlikely that you would be dissapointed with any of the products from Yamaha, Denon, Onkyo, H/K, etc. Go out and listen to it if you can, I think you'll like it.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Thanks very much for your help
No prob. Good luck.
Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
I have the JVC running the Polk satellite and I would put in a good word for it. I often marvel that they are a near perfect match for each other.
I chose the JVC over the Yamaha actually. I was not able to audition them in the same room at the same time.
What I found was the JVC has many great features for the buck. It has a great amount of inputs, high bandwidth component switching, good variety of digital in's and out's. It's been flawless at detecting and decoding various audio modes.
Some examples are the many difference speaker setups I can choose. Sometimes I like to use the satellites, especially for home theatre. Occasionally I like to switch over to 2 channel and use some tower speakers. The JVC receiver seems to have a nice intelligence built in, based on whether I pick 2 channel, all speakers/stereo, front spks 1, front spks 2, etc.
The only drawbacks I've found on the JVC (and these are minor points believe me)
- there is some quiet audible ticking as I change the volume, but only at the high volumes.
- there is no way to set Left/Right balance!
