Rtia1 and csi a4 a good upgrade?
1QWK510
1QWK510 Posts: 19
edited September 2011 in Speakers
I started putting together my first HT system about a month ago. So far I have purchased a denon avr 1712 and some energy cb-5 bookshelves . Gonna purchase my sub Hsu Stf-2 and a center next week and am wondering if the polk rti a1 would be a good upgrade. The energy sound good, but don't wow me. I have the opportunity to pick up the polk pretty cheap and was wondering if it would be worth while to ditch the energy's. I could also biamp the polk which I can't do on the energy's? Thanks for any help. System will he used primarily for how ht and some occasional music and gaming.
Post edited by 1QWK510 on
  • larry777
    larry777 Posts: 480
    The RTiA1's and the CSiA4 will match up very well together and would be good for H/T and music. I can't comment on the energy cb-5 bookshelves as I havn't listened to them. You don't seem impressed by them though,and the polks sound like they are going for a good price and are decent speakers to have. You wouldn't have to bi-amp them, in order to get a good sound, so I would just run 1 wire to each speaker. I would get the Polks especially since you feel the price is good. They are excellent Bang for the Buck speakers. Then later on you could upgrade your fronts to towers ( Rtia5's or 7's if you get the urge ) and use the RTiA1's for surrounds. All your speakers will then match up perfectly.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • mole'
    mole' Posts: 3,160
    good starting point on the speakers
    sent ya a PM
    BTW where are you at in SoCal?
    mole'
