CSi A6 and RTi8 mod
Tungx2
Tungx2 Posts: 58
edited September 2011 in DIY, Mods & Tweaks
Here is before and after mod pic.
Lol, i used tape to temporarily trying to hold them together.
The tape didn't really do much, it caps are in those positions already.
the black cap was Axon TrueCap 82uF 250VDC.
that alone cost $28.40
the rest are all sonic caps and mills resistor
TV.......................Samsung 46" LCD LN46A550
A/V Receiver.........Yamaha RX-V3900
Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
BluRay Player.........Sony PS3
Fronts...................RTia9 (modded)
Center.............. ...CSiA6 (modded)
Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
Rear Surrounds.... Deciding if front presence is the way to go instead.
Sub..................... SVS PB12-plus/2
Post edited by Tungx2 on
    VR3 Posts: 29,535
    Looks solid
    Need a bit of glue though and you will be set! :)
  • Tungx2
    Tungx2 Posts: 58
    lol ya, don't have glue gun, would be doing it with rti-a9 for sure though.
    here's a before and after for RTi8
    just did a pair for them and the other pair of RTi8, i'll wait until i got a weekend when I need something to do.
  • Tungx2
    Tungx2 Posts: 58
    Is it necessary to modify the orange/red coils? one rectangular shaped and one circle shaped. would there be a difference in quality?
    VR3 Posts: 29,535
    It is a good thing to modify the one with the iron core (the larger one) but it would cost another 20-40 dollars per speaker most likely... and it would be the size of your entire crossover...
    You would have to decide if that is what you want to do. It usually helps with bass response and accuracy.
