Vishay/Dale resistors
quadzilla
Anyone tried these? I've read some things about them that make them sound interesting.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Arm: Rega 300
Post edited by quadzilla on
Hi Quad,
I use the RN series from Dale with excellent results. I believe there was an article in AudioXpress a few years ago comparing different resistors and how each one reacted to transient peaks and the RN did the best job. I recommend using a metal polish on the leads to clean them thoroughly before installing them.
Cheers, Ken -
Hey Ken, thanks for the response. I just found Texas Components Corp., and their site says they're the US manf. for Vishay. They also said no minimum. I've emailed them to find out what the availability and pricing are.
I've been using Mills in crossovers, but have read numerous posts stating that metal film is best for audio applications, so we'll see what happens. These would be going in my 2.3 TL xover upgrade.Turntable: Empire 208
Arm: Rega 300
Speakers: SDA 2.3TL, heavily modified -
I have used the Texas Components TX2575 resistors in the output (analog stage) of the DAC I built. They are outstanding!. They have 3 different tolerance ranges, but become extremely increasingly expensive the better tolerance you get. Not sure how they would be in the 2.3TL crossovers though?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I agree, they are outstanding for line level use.I have used the Texas Components TX2575 resistors in the output (analog stage) of the DAC I built. They are outstanding!
These would work for loudspeakers, but need to be mounted to a heatsink: http://texascomponents.com/pdf/tx220z.pdf"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Anyone tried the Dale RN series? I've found someone that can supply those. Otherwise, I'm waiting to hear back from TCC.Turntable: Empire 208
Arm: Rega 300
The Placette linestages use Vishay resistors. Their webpage has some info...
http://www.placetteaudio.com/Details.htmSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I'm really looking to use these in a xover network.Turntable: Empire 208
Arm: Rega 300
I really thought this series of resistors were all used for line level. I know there are a lot of Vishay resistors in my HCA-3500 amplifier. Not sure on their application for Speaker Level Crossover networks.
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
I believe some of the TOTL B&W's use the TX220Z's mounted on a large heatsink. I'd like to compare them to Duelund."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.caddock.com/Online_catalog/power/power.html I have used the MK series in a preamp project back in the day when I could afford premium passive parts.
The resistors in your amp will in all likelihood be 1/4watt 1%metal film's which ofcourse would be unsuitable for passive crossover use.dcmartinpc wrote: »I really thought this series of resistors were all used for line level. I know there are a lot of Vishay resistors in my HCA-3500 amplifier. Not sure on their application for Speaker Level Crossover networks.
Don -
Some of those are up there in price too."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
