RTiA9 Mod thread
24
  • jbooker82
    jbooker82 Posts: 1,627
    edited September 2011
    Is the depth of the cabnets the same for the RTI A7's and 9's?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    VR3 Posts: 29,497
    Oh yeah the A9 is over 20" deep!
    We could go nuts with the upgrades if I could locate longer rods.
  • Tungx2
    Tungx2 Posts: 58
    Please please post pictures of before and after the mod of the crossovers, so we know what we are dealing with here. I'm on the wagon to get a pair for RTi A9, and I promised to mod them. Just couldn't find a decent deal on them.
    Newegg is asking for 549 each, sounds reasonable eh? That's in the US though
    TV.......................Samsung 46" LCD LN46A550
    A/V Receiver.........Yamaha RX-V3900
    Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
    BluRay Player.........Sony PS3
    Fronts...................RTia9 (modded)
    Center.............. ...CSiA6 (modded)
    Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
    Rear Surrounds.... Deciding if front presence is the way to go instead.
    Sub..................... SVS PB12-plus/2
    VR3 Posts: 29,497
    I have already gutted them.
    They look like a crossover with no room to mod them.
    They will look like this (with some differences of course) when completed
    I will post completed pics when done!
    I am still waiting on parts! Argh!
  • PrazVT
    PrazVT Posts: 1,607
    Nice - very clean. Trey, couple of thoughts for making re-installation a little easier based on my experience.
    - I think exact measurements of the opening on the back of the speaker cabs may help make sure the breadboards aren't too big. I had to chip a little off the edges when installing the xos back into my A7s. Nothing major though.
    - Might help to have that to make sure the caps aren't too wide as well. I had to kinda work them xos a little to get 2 of the caps past the opening.
    - getting the xo back in with the speaker wires is a little tough - might help to cut a shallow section on the sides to temporarily route the wires while putting the xo back in.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    VR3 Posts: 29,497
    Gotcha!
    I have started breaking the outside corners off as they are not needed for structural reasons and it remedies the first problem....
    The second problem is sometimes unavoidable due to how many caps are going on
    The third issue I can definitely try to correct the best I can...
    It is a task to get these xovers to fit in that 6" space.
    Lot of little stuff and little wires in a tight space!
    Appreciate the feedback and will alter the design as we go.
    I have done about... 4 or 5 of them at this point and all of them have been different as I make slight changes here and there based off of feedback
  • mole'
    mole' Posts: 3,160
    hmmmmmmmmmmmm
    how much of a difference are they modded?
    guess it deprnds on what mods u did
    mole'
    VR3 Posts: 29,497
    I think the best thing to describe modifications if simply this...
    It cleans everything up - its like going from a washed out sound to precision, nice precise details - gets rid of the fatigue in the top end that is due to the wash...
    It brings out the mids, opens up the bass...
    Its basically the same as going from cheap plain Jane cables to MITs...
    You wouldnt put your speakers to your amp with lamp cord - and you shouldnt use .10 cent crossover parts either! :)
  • PrazVT
    PrazVT Posts: 1,607
    Yeah just trying to help you perfect the process. I'm sure it's evolving as you do each set.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    VR3 Posts: 29,497
    We need to redo your LSi9...
    That will be a challenge integrating those Daytons! ;)
  • PrazVT
    PrazVT Posts: 1,607
    We'll do it in the near future - the thought of going with out my LSi9s for a few weeks causes me separation anxiety lol.
    I'm not even sure if the Daytons will fit through the back of the speaker actually.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • PrazVT
    PrazVT Posts: 1,607
    What he said. The mods really did clean up the A7s and A6. Add to that dynamatting the driver baskets and with the volume turned up, the A7s put out clean pounding sound.
    About the only thing missing is a more neutral vifa like drop-in replacement for the tweeters.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    VR3 Posts: 29,497
    I can separate the three caps - we can make it work! :)
  • Drenis
    Drenis Posts: 2,871
    So are the crossovers in the A9s currently garbage? I guess to me it seems odd to spend a lot of money on a pair of speakers that should be "perfect out of the box" you know?
    What's something like this cost and will I enjoy the mod or hate it? How do you determine what parts internally to replace with?
    VR3 Posts: 29,497
    The crossovers are not garbage the parts are just low cost because they are mass produced...
    I will send you a PM.
    I use parts I have tried and feel are the best out there to replace the parts that are on the stock boards...
    The mods take the sound of the speakers and draws out that extra percent that is not possible with the stock xovers...
    VR3 Posts: 29,497
    Parts
  • Drenis
    Drenis Posts: 2,871
    That's gorgeous.
    Saw your PM. Maybe in a couple months we'll talk ;).
    VR3 Posts: 29,497
    Sounds good!
    The RT series is great as is but can be better! Enjoy!
  • Tungx2
    Tungx2 Posts: 58
    damn, it's definitely a work of art to assemble it together with new layouts.
    so does that include all the caps that is modified? was there any that you skipped? i hope there's enough room for other types of caps (larger ones)
    VR3 Posts: 29,497
    I did not completely replace the larger capacitors as it would ultimately up the mod cost a couple hundred dollars.
    I am certain I could make them fit with some creative thinking and strategic placement but another day! :)
    The real important thing is the highs and mids and we are decking those out so it is all good! :)
  • JimAckley
    JimAckley Posts: 1,138
    Have you considered doing what they did in the 707s, which is split the crossovers up into two separate sections. Instead of trying to sandwich it all onto the back of the terminal cup, make a daughter board to remote-mount the HF section up behind those drivers (or at least mounted higher-up against the back- or side-wall, and then have another board for the woofer section. It makes installation a little less hectic :smile:
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
    VR3 Posts: 29,497
    I can do that but I am going for an all in one, easy to reinstall package.
    Its what I do.
    I take the impossible and make it awesome!
  • JimAckley
    This is true :biggrin:
    - Computer Rig -
    - Main Rig -
    EndersShadow Posts: 17,713
    JimAckley wrote: »
    Its what I do.
    Yup, also keep in mind I think he has just the crossovers. If he had the speaker he could just mount them in himself and be done.
    IF I do my LSi 15's I would physically drive them to him, and then pick them up later so he could do something similar with them.
  • Drenis
    Drenis Posts: 2,871
    What do the stock crossovers look like?
    VR3 Posts: 29,497
    In my picture - the things wrapped up in the wire are the stock crossovers.
    They are sandwiched together and allow maybe... a .25" of room between boards. Physically impossible to mod without doing something like I do
  • jbooker82
    You could always use some industrial strength velcro and some type of conector. That way all he has to do is stick on the remote xo and plug it in to the pig tale coming off the original xo. That way it is plug and play.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    VR3 Posts: 29,497
    That is always an option...
    I personally dont like using quick disconnects for anything...
    But if it came down to it we can definitely do it.
    At that point I think I would try to talk the individual into external crossovers though! :)
    VR3 Posts: 29,497
    Finished CSiA6 mod that goes with the A9 - going to knock out the 9's tomorrow!
  • jbooker82
    Man that cap is massive
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
