Vishay/Dale resistors
quadzilla
quadzilla Posts: 1,543
edited September 2011 in DIY, Mods & Tweaks
Anyone tried these? I've read some things about them that make them sound interesting.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hi Quad,
    I use the RN series from Dale with excellent results. I believe there was an article in AudioXpress a few years ago comparing different resistors and how each one reacted to transient peaks and the RN did the best job. I recommend using a metal polish on the leads to clean them thoroughly before installing them.
    Cheers, Ken
  • quadzilla
    Hey Ken, thanks for the response. I just found Texas Components Corp., and their site says they're the US manf. for Vishay. They also said no minimum. I've emailed them to find out what the availability and pricing are.
    I've been using Mills in crossovers, but have read numerous posts stating that metal film is best for audio applications, so we'll see what happens. These would be going in my 2.3 TL xover upgrade.
    Arm: Rega 300
  • headrott
    headrott Posts: 5,496
    I have used the Texas Components TX2575 resistors in the output (analog stage) of the DAC I built. They are outstanding!. They have 3 different tolerance ranges, but become extremely increasingly expensive the better tolerance you get. Not sure how they would be in the 2.3TL crossovers though?
    Greg
  • Face
    Face Posts: 14,340
    headrott wrote: »
    I agree, they are outstanding for line level use.
    These would work for loudspeakers, but need to be mounted to a heatsink: http://texascomponents.com/pdf/tx220z.pdf
  • quadzilla
    Anyone tried the Dale RN series? I've found someone that can supply those. Otherwise, I'm waiting to hear back from TCC.
    Arm: Rega 300
  • steveinaz
    steveinaz Posts: 19,545
    The Placette linestages use Vishay resistors. Their webpage has some info...
    http://www.placetteaudio.com/Details.htm
  • quadzilla
    I'm really looking to use these in a xover network.
    Arm: Rega 300
  • dcmartinpc
    dcmartinpc Posts: 844
    I really thought this series of resistors were all used for line level. I know there are a lot of Vishay resistors in my HCA-3500 amplifier. Not sure on their application for Speaker Level Crossover networks.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • Face
    Face Posts: 14,340
    I believe some of the TOTL B&W's use the TX220Z's mounted on a large heatsink. I'd like to compare them to Duelund.
  • FTGV
    FTGV Posts: 3,650
    http://www.caddock.com/Online_catalog/power/power.html I have used the MK series in a preamp project back in the day when I could afford premium passive parts.
  • FTGV
    FTGV Posts: 3,650
    dcmartinpc wrote: »
    Don
    The resistors in your amp will in all likelihood be 1/4watt 1%metal film's which ofcourse would be unsuitable for passive crossover use.
  • Face
    Face Posts: 14,340
    Some of those are up there in price too.
