That one piece that you shouldn't have let go...
    tonyb Posts: 33,065
    edited September 2011
    Drenis wrote: »
    Hmm... I've had good experiences with 2 different Technics EQ's, most recently early this year when I sold my SH-8057. I thought it was a very solid unit. All the specs suggested so... so i thought.
    Seems perhaps I can do better. I would certainly take the advice. Anything to combat the inefficient Pioneer EQ I dislike fiddling with.
    Also, I haven't found a SH-8057 for less than $80 used when I DO find one. I sold mine for $100 back in January.
    I'm just yankin' your chain Drenis.:tongue: Though equalizers and me don't gel well together, If that floats your boat,rock out to it by all means.
    If you don't like the equalizer in your receiver, why not just not use it ? If you have a direct mode,or pure audio mode, that will bypass the equalization you dislike.
  • Drenis
    Drenis Posts: 2,871
    stuwee wrote: »
    You need a real EQ, a parametric, Find a SAE 180 for around $50 on ebay, I have one, no pretty flashing lights, just more control than any graphic EQ, you get to adjust frequency, bandwith and level for highs and lows in both channels separately.
    I always understood that slider style controls are more susceptible to noise in the stream as they get dirty. (Had an Old Toshiba receiver that had sliding controls and it sounded terrible.) Thats why i liked the digital controls of the Technics.
    tonyb wrote: »
    I've played around with my Pure Direct mode on my Elite but I find that it doesn't sound as good as Stereo or Direct with Sound Retrieval enabled. Hell, maybe I am doing something wrong.
    I'm very familiar with most people disliking the EQ. I certainly needed one when I had the Bose ;)
    heiney9 Posts: 25,398
    Drenis wrote: »
    They all add noise no matter what type of controls you use, they are a bandaid for sure in most cases, unless you have serious room issues. If room issues are the case then a standard EQ won't help at all.
  • mole'
    mole' Posts: 3,160
    SDA SRS 2.3 TLs
    mole'
  • audiocr381ve
    audiocr381ve Posts: 2,588
    mole' wrote: »
    SDA SRS 2.3 TLs
    :rolleyes: Not buyin it!
  • dcmartinpc
    dcmartinpc Posts: 844
    mole' wrote: »
    SDA SRS 2.3 TLs
    That was quick :frown:
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
    tonyb Posts: 33,065
    Drenis wrote: »
    If it sounds bad in direct mode, then your source isn't up to snuff. What are you using as a source, and what kind of cable is connecting the two?
  • mole'
    mole' Posts: 3,160
    dcmartinpc wrote: »
    Don
    i will regrt it. i know it.
    i should have just put them in a climate controlled storage unit.
    but they are going to a good home.
    mole'
  • audiocr381ve
    mole' wrote: »
    :smile:
  • leadfoot1
    leadfoot1 Posts: 155
    Anthem AVM30. Should of just moved it to the bedroom instead of using an old receiver in there.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    KLH 9, sniff sniff...
  • Evrythngmatters
    Evrythngmatters Posts: 187
    I had a pair of Legacy Whisper speakers years ago. Picked them up from a friends father for $1200.00 back in the day. I had no idea what they were other than that they played loud as all get out. Would really like to see how they sound since my ears are tuned better now. Back then they were nothing more than a party speaker to me.....who knows they could still be just a party speaker for all I know since my listening skillz have improved.
    Everything matters. That is all.
    Money cannot buy happiness, but it sure can buy a bad **** boat to pull up along side it though.
  • Tbone289
    Tbone289 Posts: 661
    $1200? I don't mean to rub it in, but hell yeah you should have kept those Whispers!
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    tonyb Posts: 33,065
    Whispers for 1200.....man, you do know what retail is on those bad boys ? Sure wouldn't put them in the class of party speaker though. Cerwin Vega...yea, Whispers, uh...no.
    Unless they were beat to all hell, but even the cabinets and parts are worth that.
  • dekuda
    dekuda Posts: 756
    Regret selling my Infinty RSII's. Loved how they looked and sounded. Should have just kept them but the wife......:frown:
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • Evrythngmatters
    tonyb wrote: »
    The speakers were in awesome shape. Nothing wrong with them at all. I liked them cause they were big and loud. I never listened to them how I listen to music now. Hell, Bose probably would have sounded awesome. I did not know any different. Back then I listened to pretty much anything but I was in my Metallica,Slayer,Pantera days then so that's what was pretty much played on them. I still remember listening to Seasons in the Abyss by Slayer so loud that my neighbors wanted to tell me to turn it down but they were scared (the father told me later that his wife would not let him come over). They probably thought I was a Satan worshiper or something,lol. Right before I went into the military I sold them to my buddy.
  • sk1939
    sk1939 Posts: 295
    Complete set of McIntosh separates (Pre, 2 Power amps, tuner, environmental equalizer) with speakers (ML-2C) and cabinet.
    Home:
    Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
    Home 2 (Playback):
    Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
    College:
    JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII
  • falconcry72
    falconcry72 Posts: 3,580
    This is a little bit of a reach for "audio" equipment here, but...
    A Paul Reed Smith McCarty.
    StreamImage.aspx?Image_ID=464550&type=gear&Image_Type=full
    StreamImage.aspx?Image_ID=464549&type=gear&Image_Type=full
    I miss her now more than ever. :frown:
    nooshinjohn Posts: 25,877
    What curves she had....
