Vifa frankenpolk question
phocion
phocion Posts: 157
edited September 2011 in DIY, Mods & Tweaks
So, I have a couple of blown SL2000 tweets sitting around, and I have been considering taking the face plates and modifying them to accept a vifa 1" ring radiator tweeter after listening to a set of LSI 9's. The tweeter in the 9's was so crisp compared to the SL's and 194's, and I have been lusting ever since.
I have a few pairs of 5jrs that I can do a side by side with, and if it works well, I might put them in a my monitor 10s, but I figured someone on here must have done this before, and might have some advice. X-over mods, mounting tips, sound comparisons, all input is welcome!
I am thinking I might be better off fabricating a metal plate to mount the vifa on...
The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
Post edited by phocion on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2011
    You're going to have an impedance mis-match first and foremost, along with efficiency. It's not going to be a drop-in mod, you are going to be asses and elbows in the crossover.
    Not crapping on your project, but all things equal, if I were in your shoes - I'd buy some RDO's and maybe drop a Sonicap in the crossover of your 10's, or just get some LSi9's on the used market, and either way, I'd call it a day at that point.
    Cheers,
    Russ
    F1nut Posts: 51,954
    edited August 2011
    ^What Russ said^
  • phocion
    phocion Posts: 157
    edited August 2011
    I completely agree with your assessment, and I should have mentioned that this is entirely a screw around project for me. I enjoy blowing off steam with a soldering iron or a dremel in my hand. I have a worked over pair of 10s that are doner boxes sans tweeters that I figured I could play with.
    I would never violate the sanctity of my sda's. Well, aside, from caps, gimpboards, rings, and RDOs :) - dynamat drivers are next!
    I have been browsing the used LSi market for a while, and I am hoping it opens up a little as people pick up the LSiM 703's.
  • Joe08867
    Joe08867 Posts: 3,919
    For the fooling around idea I would go metal plate before trying to mod SL2000 face plates.
    Toolfan66 Posts: 18,162
    Knock yourself out and have fun!!!
  • Joe08867
    I meant to add, either way you go I hope you give us some pics to check out.
  • Face
    Face Posts: 14,340
    The Vifa ring radiator isn't the simplest tweeter to work with, an off the shelf or online crossover calculator will not come close.
  • ohskigod
    ohskigod Posts: 6,505
    if they still have those RDO drop in replacements, just buy them and drop them in. one of the best dollar for dollar mods I made to a speaker back in my SDA ownership days.
    as much as I love the Vifa tweet, there is no way I'd touch that project with a 10 foot cattleprod. the RDO's are too nice, cheap and easy to make the trouble with the vifa worth it.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
