SDA 1.2tl's with Dueland Resistors
Toolfan66
I ordered some Dueland Resistors some time ago and they finally made it to the USA.. I ordered short tubes as they are about 5" LONG these are about 3" LONG and still a pain to fit even with a custom board.
I think they look pretty good considering what I have to work with, I am looking forward to finishing and putting them to work..
Post edited by Toolfan66 on
Lovin it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Just finished putting the crossovers back in with a little SADE paving the way for a few hours..
Thanks Trey.. -
Not a fan but they're better than stock.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Would love to hear why.
How much did each of those run you bro? -
What was it you didn't like about them Mark?? For me it's just their length that makes it hard to use.. I love what I'm hearing in my CRS+'s, and hope to like them just as much in the 1.2's.. I will be able to tell this afternoon.. -
TOOLFORLIFEFAN wrote: »What was it you didn't like about them Mark?? For me it's just their length that makes it hard to use.. I love what I'm hearing in my CRS+'s, and hope to like them just as much in the 1.2's.. I will be able to tell this afternoon..
I was wondering the same thing. I have all mills in my SRS 2 p/b crossovers, but after seeing you can get the deulunds a little shorter, I am very tempted to swap them out! Do they have a price list for the shorter versions?
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
I had to email them what I wanted and they let me know what I was looking at. I also told them I wanted longer leads as well.
Reported emmagal27Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
They look like cinnamon (or walking) sticks glued to the xover. Interested to hear how they sound vs Mills...
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198 -
Ditto"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Duelund are far more sterile sounding than Mills but in a way that you hear more details and it stages better.
In my experiences synergy has far more to do with resistors than quality - I have used 1.50 resistors that I liked better than Mills and Duelund.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ahem..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Quick update I am loving the detail that the Duelands give the sound stage so much better then the Mills, Funny thing is when I first was listening I was hearing so much more detail I would hear these little clicks and snaps and it took me a few to realize that I was hearing the drum sticks hitting with so much better clarity at first I thought something was wrong LOL!!
All the little details are so much cleaner it's insane, and with them settling in after a few days it's that much better. The only down side to them is the cost they are not cheap when you need as many as I did for the 1.2tl's, and when you order them custom with a shorter tube and longer leads so they will fit the boards better that is an extra cost as well..
Thanks to Mike (Face) for pushing me over the edge.. -
Ohhhh let me add that the Piano Keys are off the hook as well with the new resistors not that they were bad before but man oh man are they clean when they hit..
What about the Dueland (physically) makes them sound better than the Mills?
Not sure what it is physically, to be honest I would still like to know why it has to be a long tube.
Face might know more.. -
Uhm, carbon resistor element instead of wirewound?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I see - so carbon inherently sounds better than wire-wound - interesting.
I wouldn't say "inherently". I'm pretty sure they do a bit more than just stuff a piece of graphite into a case with a couple of leads. But to get to real specifics of construction, well, I doubt they'd tell you, me, or anyone else exactly how they're made.Turntable: Empire 208
Arm: Rega 300
Similar concept, if you want to make your own Graphite resistors: http://www.troelsgravesen.dk/graphite.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Cool link, thanks!Political Correctness'.........defined
President of Club Polk -
That is fascinating, and I believe explains why they are so long. Thanks!
That was a good read. Thanks!! not part of the hobby I want to dig into though,, -
Totally great information. It's amazing how deep we go into this hobby.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Larry, did you just leave a mills resistor in the polyswitch spot? Or, just a jumper? It's a little too dark for me to tell. I wouldn't think you would need to go so far as to use a duelund resistor here, would you? Or, maybe it would be better? Thanks again.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Greg
I am just using the .5 mills and it is mounted under the board..
Edit in that pic I was using a jumper. -
OK, that's what I figured. That'll save me about $100.00.:cheesygrin: Thanks Larry.
Greg
For the record I prefer the Duelands over the mills the detail and clarity are by far better IMO..
very nice Larry. I bet they're some very sweet sounds coming out of those 1.2tl's
Did you use Cast Duelands or the silver/carbon ones?
I just emailed them and they recommend the cast resistors at the cost of 40 euros ($52) each!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
