Wiring for RM6750
Hi guys i recently bought Polk Audio RM6750 5.1 Channel Home Theater Speaker System i need advice on what wiring i need to buy to set it up!!! and can you guys suggest me if i can hook this up to my laptop or do i need a reciever/amplifier.
Thank you in advance!!!!
Post edited by nikhildeshmuk on
  • larry777
    larry777 Posts: 480
    edited August 2011
    Yes you will need a Receiver to run this speaker system. Pick yourself up some 16 guage speaker wire to attach the Satellites to an A/V Receiver. Then get yourself a single Sub Cable to hook up your sub to the Sub out on the back of your Receiver. Then follow your manual setup instructions to get the best sound you can from your system.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
