Subs for my 2ch system
cokewithvanilla
cokewithvanilla Posts: 1,777
edited August 2011 in 2 Channel Audio
Hey everyone. I finally got settled in my apartment, so it's time to think about some subs.
I have all my gear set up in a room that measures 19'3'' wide (this is the wall with the speakers), 11'9'' deep, with 9 foot ceilings. The room opens into a kitchen, which opens into a foyer. The measurements for this area are: 19'6'' wide, 8'9'' deep, also with 9 foot ceilings.
I will probably be doing 50/50 between movies and music. I have no plans to make this a 5.2 setup. I will be using the Tyler Acoustics speakers I got from Trey, along with my Aragon 2ch pre and Adcom 5800. The Aragon has no room correction.
I have no budget yet, but I probably want it to fall in line with the rest of the gear. I am up for new or used gear (whichever gets me the best value)
Here's some pictures of the room:
this is the area it opens into:
Post edited by cokewithvanilla on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2011
    Dont know about subs but that is a nice clean relaxing listening area
    tonyb Posts: 33,065
    edited August 2011
    Seeing that your in an apartment, you really think a sub is going to make friends ?
  • PrazVT
    PrazVT Posts: 1,607
    edited August 2011
    Maybe a smaller sub that'll just fill in where the bookshelves drop off? That's how I'm using my 2000. Once you get the volume / xo dialed in, it may not be very obnoxious. I'm on the 3rd floor so I worried about it for a year before adding a sub.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • cokewithvanilla
    edited August 2011
    PrazVT wrote: »
    That is mostly what I am trying to do. I hooked up the Tylers along with the 25's subs and noticed how much I was actually missing. Though if I am buying subs, I do want them to be able to add some punch to movies as well.
  • pietro944
    pietro944 Posts: 720
    edited August 2011
    I went with the Def Tech pro sub 60.....$170 w/shipping......Has 5 way binding posts,unlike the spring clips on other low-cost subs....VIP to me.
  • Splif
    Splif Posts: 114
    edited August 2011
    I really like your TV stand. Where did you get it if I may ask?
    Pn51D550
    Panasonic DMP-BDt110
    Onkyo HT-RC360
    Polk Monitor 60's L/R
    Polk CS2 C
    Polk Monitor 30's SL/SR
    BIC F12
    XBOX 360 COD:MW2 250g edition
    Logitech Harmony One
  • decal
    decal Posts: 3,205
    edited August 2011
    Splif wrote: »
    It looks like a Whalen stand. Check BestBuy.
  • cokewithvanilla
    edited August 2011
    decal wrote: »
    It's a Kennedy stand, actually. I got it from Sam's Club. Whalen makes a similar stand that can be found at best buy, but I noticed that it seems to be of lower quality.
    http://www.samsclub.com/sams/shop/product.jsp?productId=prod3040201&navAction=push
  • erniejade
    erniejade Posts: 6,321
    edited August 2011
    On my tyler's I tried out a few subs but, the velodyne spl 1200 so far was a fantastic match. small in size but not in sound. Fast sharp natural hit to them Verry musical.
  • halo71
    halo71 Posts: 4,628
    edited August 2011
    If I were you I'd be looking at those 2 subs Russ has for sale. $325 shipped.:eek:
    --Gary--
  • cokewithvanilla
    edited August 2011
    Haven't heard much good about polks psw series.
    How about Rythmik F15's? How do these subs compare to similar priced subs from non internet direct companies?
  • cokewithvanilla
    edited August 2011
    Ah, well... seems as if you guys were right... second complaint from the guy downstairs already and it's only been two weeks. He literally complains whenever I turn on the system. I was told that he is an a-hole by the management, but still.
    Too bad too, cause someone has a F15 on atl CL for 475!!!
    Ugh, no subs for me :(
    EndersShadow Posts: 17,687
    edited August 2011
    You could always be an **** back :biggrin:
    Thats one thing I hate about my apartment. Thankfully I have a townhome so only 2 neighbors and really only one that would have a problem since we share one common wall.
    But they are really nice and so far only two complaints about my bass, but they came to me directly and I was very happy to turn it down for them.
    It does hurt having LSi's I cant let "breathe" but it gives me something to look forward to
  • cokewithvanilla
    edited August 2011
    Oh, don't you worry on that front. The minute I got the complaint, I turned the music up. His last complaint was about my sound machine that I use to go to sleep. He's lost all credibility with me. I told the management that next time he complains, he needs to state a reasonable decibel level that I am allowed to listen to my music at.
    I mean come on, it's 2:30 on a Sunday.
    edited August 2011
    hehehe.....HB27 put some SDA's in his house once at full volume with an amp and then left for a couple hours once lol...
  • 20hz
    20hz Posts: 636
    edited August 2011
    nice looking setup !
    I think using 2 smaller subs one on each side of your cabinet would look best .
    something like the size of a yamaha I saw it was a bandpass only like 12" wide but it was deep and tall.
  • nhhiep
    nhhiep Posts: 877
    edited August 2011
    About the suggestion for deftech pro 60. I've a newer version of it, pro 600. it's terrible sub for the price. it's only 8" and bottom out very easily and it doesn't go low at all. construction is very cheap, it's very lightweight and the cabinet is thin too. it's rated at 250W, but I think that is the peak, not RMS. I have other subs around 250-300W from Infinity and they blow this deftech, I am guessing the RMS is around 100W.
    For just $200, get a polk pws505 or BIC F12 and put it in the corner of your setup would be my choice.
    don't get me wrong, I like Deftech stuffs (also own supercute 1). but the ProSub line is junk for the price.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2011
    sorry about your neighbor, you might consider the Aurelex gamma's, they will isolate the sound from the floor very well, but some people just have a need to complain find something annoying he does and complain back if you like. btw, the polk psw are fine subs, not one note wonders like so many others I have heard at their price point.
    RT1
    treitz3 Posts: 19,945
    edited August 2011
    If your neighbor wants peace and quiet, he shouldn't have moved somewhere where all of his neighbors are only six inches away. Walk heavy, drop things and fall often. I hate stupid people like that.
  • cokewithvanilla
    edited August 2011
    RT1
    do you think that would be enough for me to get a sub? I kinda doubt it, but damn, someones got a great deal on this thing
  • reeltrouble1
    edited August 2011
    well, the way they work is the sub sits on top of the gamma, it tightens up the bass and prevents transfer to the floor...so that will lessen the thump he hears...now if there is a common wall...say from the ground floor up to the next sound waves striking that wall will transfer...not much you can do about that except sound covering all over the wall and that prob. cost too much and not worth the trouble. If the guy is complaining without the sub...well he complains, I dunno you can try to reason with him if he is that type, tell him what you are doing and maybe reach an agreement as to times and all that...he does not get to have everything his way...others have rights and seems the landlord knows the guy is a pita.
    the gamma from Aurelex for the subs sell for around 50-60 bucks.
    hope that helps a little.
    RT1
  • DMara
    DMara Posts: 1,434
    edited August 2011
    The Polk Audio microPro series would provide one of the best values for such a room. They're musical while quick and powerful.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • DMara
    DMara Posts: 1,434
    edited August 2011
    RT1
    I think you're talking about the Auralex Subdude (HD). I got a couple for my JL Audio Fathom F113's.
    Living room:
    Bedroom:
    Other rooms:
    VR3 Posts: 29,384
    edited August 2011
    Nice room!
    Good to see someone really enjoy those Tylers!!
    Where the heck did you find that couch - I freakin like that design.
  • cokewithvanilla
    edited August 2011
    Nice room!
    Yep, still enjoying them. The couch is totally legit... it's the most comfortable thing I've ever sat in, nice leather too. I got it at a consignment shop... they had the whole set, but this was the only one I could fit... I believe they still have the others. I have no idea where to find something like it, I did so much shopping and found noting close.
    Got ANOTHER noise complaint from the asshat below me. I told the management to come in and play with my equipment and find me a reasonable volume or give me a decibel limit.
