1.2tl cabinets gutted FREE!!!!
HUGE demand for the badges, don't burn them up !:eek::biggrin:
Those are staying in my goody box. -
Looks like Nick will be picking these up.. I will update later..
Nick came by and picked these up this afternoon so that means the wood caps are gone fellas. I am looking forward to seeing what Nick does with these.
Thanks Nick,and sorry about the wife not sure what the hell she was thinking but all is good.. -
Please don't mark these as sold as I want to re-list them for a going rate of $100 each! (wood caps extra)
Just kidding fellas, I plan to turn one of them into a blu-ray cabinet where the grill opens up on a hinge. Hopefully I can put some drawers into the bottom to slide out for extra cables, remotes, magaiznes, and anything else. Likely wire some sort of light through the speaker terminal hole in the back.
If things turn out well, and the interest is there I will likely do the same with the 2nd speaker and figure out something with one of you sda **** (audio_alan).
Thanks again Larry -
Nick,
Have you cut into these yet?? -
One of them is completely gutted out. All the supports and face are ripped off. I sanded down the two side boards and the cap and bottom of the same speaker as well.
Next step is to cut some boards to completely re-do the inside and make everything pretty again as the particle board these things are made out of doesn't look the greatest. Stain everything the same shade inside and out, re-do the fabric, connect it all up and put some shelves inside...
I haven't had a day off in 9 days now so I haven't worked on them at all in quite a while but hopefully wednesday and friday I will make some more progress and get some stuff done. -
u still have these?
nvm just saw that they were picked up
