amp
Systems
is a 1000watt sony explod amp have enough juice to power two 15'' directed subs or should i get another amp or will another amp even make a difference
Testing
Testing
Testing
Testing
Testing
directed what --- what model, what impedance... how will they be wired... what is the rated output power of the amp at varying impedances... basically you've asked a question that is impossible to answer without you supplying any of the pertinent information.
any sony is pretty much garbage anyway, so dont waste your time or money.The Artist formerly known as PoweredByDodge -
I will agree with Vinnie here. I'm not a sony fan. I know too many who have had major issues with them. If you need a cheap amp- look at planet audio or power accusitcs.... decent bang for the bux. also..you can find some older great amps at good prices on EBAY.
dont sell short... good luck -
I second that Sony car audio SUCKS!!!:D
actually, you would be thirding that
