Ok all you big amp brains...
brgman
brgman Posts: 2,859
edited September 2011 in 2 Channel Audio
If i take 2 Carver M1.0t amps and run them in Mono instead of stereo can i run with my 2.3TL's with the stock interconnect or if not how do i wire these up? thanks in advance for the help.
I’M OFFENDED!!!!
Post edited by brgman on
  • strider
    strider Posts: 2,568
    edited August 2011
    AFAIK, you'd need an AI-1 or similar isolation device for running anything monoblock with an SDA.
    Wristwatch--->Crisco
  • Gavin.Wright
    Gavin.Wright Posts: 125
    edited August 2011
    I'll 2nd that. I would expect that since each amp is being run in bridged mode that neither speaker connection would be common to chassis ground so you wouldn't be able to tie the two amps grounds together.
    heiney9 Posts: 25,396
    edited August 2011
    brgman wrote: »
    Nope you need the AI-1 instead of the stock interconnect. Bridging stereo amps is overrated and may not work with SDA's because each amp will see half the normal load. So if the SDA's are 6 ohm nominal running a bridged stereo amp means the amp sees 3 ohms or less, typical amp might not like that.
    Why do you feel you need to run 2 stereo amps in mono?
    treitz3 Posts: 19,945
    edited August 2011
    Even if you do run the 2 mono with the AI-1, the bass will get sloppier than if you just used one of the M1.0t's in stereo. Waste of time and money.
    nooshinjohn Posts: 25,877
    edited August 2011
    I may be very wrong on this, so do NOT attempt until someone with better experience chimes in, but I think you can use one amp to drive the highs and the other on the mid/bass. Doing it this way would perhaps also eliminate the need for the AI-1
    edited August 2011
    ...and lose the SDA? No thanks.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2011
    I used some bridged NAD 2700 a while back with 1C's and the AI-1, it worked pretty good and I did enjoy the sound, I suppose it was a stepping stone to learning about larger powered amps while looking for a refined sound. NAD though incorporates a soft clip in their circuit as well as being able to deliver large amounts of dynamic power so I did not use the amplifiers you are considering.
    If you do it I would advise to take it easy and see how they sound. You can also bi-amp as suggested, we did this at one of the Carolina Fests with a pair of Anthem hybrid amps and sound was excellent, once those two amps went into the rig they stayed. If you bi-amp you must remove the jumper from the back of the speakers.
    RT1
    edited August 2011
    treitz3 wrote: »
    How would you loose the SDA on a vertical bi-amp?
  • chandler9a
    chandler9a Posts: 878
    edited August 2011
    treitz3 wrote: »
    I've done this with two NAD 218THX amps, one for the highs and one for the lows on my fathers 1.2TL's. Never had a problem with it...Sounds pretty good actually.
    This method may not be for everybody or every system but I suggest the OP try it and sees if he likes it.
  • chandler9a
    edited August 2011
    And a regular SDA cable was used with the bi-amp method
  • george daniel
    george daniel Posts: 12,096
    edited August 2011
    chandler9a wrote: »
    yes--as RT1 said,,just remove the jumpers on the speaker.
  • Systems
    Systems Posts: 14,873
    edited August 2011
    heiney9 wrote: »
    +1...great advice...this one is out of my experience..but i do believe heiney9 is right on about inputting the two amps..
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    edited August 2011
    ctank wrote: »
    Well i have 2 and was curious what you guys think of a setup like this and how it would/could work.
    Right now using one for highs and one for lows semms to be the only thing worth trying if i am reading this right.
    The ohm factor H9 brings up is one i never would have thought of.
    Thanks guys...
    I’M OFFENDED!!!!
    edited August 2011
    Also if you choose to vertical bi-amp make sure the output on both amps is the same. I assume (that gets me in trouble alot) your pre-amp has (2) outputs or a way to jerry-rig it is to use a Y-splitter. Vertical bi-amping is certainly worth experimenting with but I never really understood why people do it. Sell both amps and move up the chain if you aren't all that happy with a single 1.0T rather than mess around with bi-amping, but that's just my opinion.
    Good luck
  • chandler9a
    edited August 2011
    heiney9 wrote: »
    Good luck
    This is a good point, while I'm not sure what I could get for Two NAD 218's, I could possibly sell them both to buy something better up the chain.
    something I have been pondering is a Parasound Halo A21. I have never heard it but like what Ive read so far.
    Any thoughts on this being a "step up" in the food chain compared to Biamping two NAD 218's?
  • reeltrouble1
    edited August 2011
  • Goth child
    Goth child Posts: 38
    I run 2 Cambridge Audio 840w power amps with my 1.2tls.I run them bridged.Stereo they are 200wx2,bridged they are 500w each into 8ohms/800w into 4ohms.Its an affordable way to buy new and get that kind of power and quality.
    An A1 dreadnaught keeps my "girls"safe,whilst still retaining the sda.
