wires
fastreddie
Is tinning the wires recommended on all connections?
Also, how can I best determine speaker placement with angled walls, etc.? Thanx
Never have tinned speaker wire. Don't believe it's necessary...
Need a pic or a room description before I disagree with ATC on the 2nd question...:DMore later,
Tour...
Vox Copuli
Basically my room has an entertainment niche and I ran conduit in the walls before the drywall.
OK, but the question is where are the angled walls, etc., vs. where you'd like to place the speakers?More later,
Tour...
Vox Copuli
Basically my room has an entertainment niche and I ran conduit in the walls before the drywall so I could run sats on the front and back walls/ceiling.
Image might have been a little too big there, sparky...
Feels like I'm peeking in through the blinds... not that I've ever done that...More later,
Tour...
Vox Copuli
Well I was going to post some pictures here, and try it like SID the KID has said he was doing. The is a large picture and some software here on this forum was compressing the picture that he post's....
As this picture is a large pixel / large memory size and the broad killed the picture in short.
O well that kills that question in my mind...Originally posted by Tour2ma
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Sorry I had a few tech difficulties. Let me try that pic again. Got a kick out of your comment about the blinds...
Closer to it...More later,
Tour...
Vox Copuli
Dude.....
Talk about placement challenged.....
:eek:
I dont know how you could actually go around that...
Bookshelves, swivel(sp) brackets?
Dang......
Disney,
I use PSP, JPG - nothing special bro! - here is what the camera can do with good light
http://www.alektra.com/00_00035.JPG - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Man, you have a couple of options here...
1) Place the bookshelfs on the straight wall directly above the TV...............................
2) Place a bookshelf on the slanted wall on a swivel bracket ahead of the tv, then another bookshelf on the straight wall, invest in a SPL meter and go happy......
That is a REALLY challenging room.......
How far away are you seated from the main stage? More options could be there if you are pretty far back...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I will be sitting about 12 feet and I already have Polk satillites
that I thought I would mount on the ceiling/wall. -
You could definetely work with the ceiling....
Since you are about 12 feet back...
I would mount one at the beginning (opposite side of tv) on the slanted wall, then the right side of the door frame at the ceiling and angle at your main listening positions. *YOU WILL NEED A SPL METER*.
That is my take. Hope that helps.
Are you mounting the center channel on the ceiling also? or above the tv?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3, thanks for the input I'll definately check into the
SPL meter. I found some swivel mounts that I think I can make work. Probably will put the center on top of the TV. -
If that fireplace is for real, it is going to compromise the left channel placement.
Even if it didn't, with the wall at that angle I don't think in-walls will rotate far enough to center the image across the room and in front of the TV...
Very tough room there...More later,
Tour...
Vox Copuli
