5 way binding posts
ken brydson
OK, serious newbie question. I'll probably feel pretty silly when someone answers....
1) bare wire
2) bananas
3) spades
4) pins
5) WTF is the 5th option?
1) bare wire
2) bananas
3) spades
4) pins
Post edited by ken brydson on
Originally posted by PolkThug
good question
Thank God I'm not the only one. I feel better now -
They'll take ring lugs as well ... However I think what they're really referring to is the capability to take banana plugs two ways.
The answer is "dual banana plugs". If the posts are spaced correctly, they will accept a dual banana plug.
Regards,
PolkThug -
Regards,
PolkThug
Hmm. I would think that would fall under bananas, single or dual. Maybe not. Good answers guys.
Now I can go back to thinking about something more important, like lunch
I emailed a link to this thread to CS. Hopefully they'll chime in with the definative answer
I found this on partsexpress.com
"Five-way Binding Post: A type of connection usually found on speakers and amplifiers used for connecting speaker wire. The term five-way comes from its ability to connect to multiple wire termination methods: bare wire (compressed under the nut), bare wire (through-hole), speaker pin, spade plug, banana plug, and banana plug (through-hole). Used very often on high-end speakers for its flexibility and ease of use."Proud SOPA Member since 2005! -
Makes sense. Good catch!
Except of course that that's 6.
WAAAAAAAAAaaaaaaaaaaaaOriginally posted by PolkWannabie
Except of course that that's 6.More later,
Tour...
Vox Copuli
I could never figure out #5 either.....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
No that would be my ex-girlfriend.Twist one. For DnB. -
According to Crutchfield, dual-bananas was the 5th way.
Is it Friday yet?
