Volume Setting
deronb1
deronb1 Posts: 5,021
edited August 2011 in Electronics
Got a new Pioneer Elite VSX-23 (110x7). The Volume is in "relative" only. What would -33db be on a standard volume? Just so I have a reference.
Would it be "2" or "3"? What?
Post edited by deronb1 on
  • pietro944
    pietro944 Posts: 720
    edited August 2011
    deronb1 wrote: »
    I have the 74TXVIS.....I'd say on a scale 1-10,it's a 4.I listen to TV and movies at-34,and that's not very loud.....Hope this helps...peter
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2011
    Volume settings on a piece of gear mean absolutely nothing. They are only useful for that particular piece of gear. Buy a Radio Shack SPL meter to get an idea as to what sound pressure the various levels produce if you really want to know.
  • EDUBAG
    EDUBAG Posts: 403
    edited August 2011
    I have the same receiver you got, I would say that most of the time you will use it between -25 to - 15 at least I usually do, but would say that depending on your speakers -20 would be enough.
    I believe the loudest I have heard my system with the receiver is minus five but that is for short periods of time when I am testing something
    Good luck
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2011
    I have a Yamaha RX V665.It's volume scale goes from an inaudable -79 to the high of the +16. My main tv and movies are at -24>-21.
    When listening to my 2-chl system I set the Onkyo P301 at the 9 0clock position and any louder would blow the neighbors away. I always wanted an amp that could over power the room I'm in and now I've got it. Adcom gfa555>>OnkyoP301>>InfinitySM112>>Samson ps80.8 surge/outlet>>YDS11Dock>>Denon1940ci>>Shure pro240 pro heaphones.
  • leftwinger57
    edited August 2011
    Sorry to repost. I actually have no idea how the Yamaha volume control setting works. Someone tried to explain some mathamatical formular which I had no idea what he was talking about and for me failing algebra 1 multiple times just does not get through the old grey matter.Now the around the clock system is oh so easy and all vol controls should be set up like this.I do not know how to look at past posts so that's also a lost cause. If someon could VERY VERY easily explain this system to me I would be forever greatfull.Even the Yamaha techs couldn't explain it where a neophyte could get hold of it....LW
    tonyb Posts: 33,072
    edited August 2011
    What exactly do you want to know ? A scale is a scale, thats all the volume dial is and it varies between gear. Whats the big deal, turn up the volume to what your comfortable with and relax. In your case, I would keep the volume dial no higher than -5 on the dial which would be pretty darn loud. Does it really matter if the dial has numbers, +or-, or some alien language ? Your ears are the volume control no matter what is on the dial. Don't sweat the small stuff LW, your going to drive yourself nuts over it.
  • decal
    decal Posts: 3,205
    edited August 2011
    tonyb wrote: »
    ^^^^^^ Ditto ^^^^^^
  • Glowrdr
    Glowrdr Posts: 1,103
    edited August 2011
    Funny thing is, before I even saw who posted, in the back of my head a little bell rang and I thought "This looks exactly like a LW post with the list".. I had to chuckle when I saw it actually was.
    LW - This is probably the easiest way to understand it. When they rate speakers or any other gear - you've probably heard the term "reference level". This is the point at which they are rating said product. Reference level is 0 on the receiver. If you turn the volume to -25 while watching TV, you are -25db below reference level
    The problem with rating anything on a volume scale, is the scale is different to everyone. Again, back to cars - it's like asking someone how fast (all) cars are at half throttle. That cannot be answered, because a Geo Metro and a Mustang have 2 different "scales" they are dealing with.
    There really is more to it than that, but that's the easiest way to explain the new volume scale vs the 1-10.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    Throw in the Yamaha 'loudness contour' and really blow your mind :tongue:
    Seriously, like the others said, too many variables to really matter. I'm old school and have always thought of it as a clock face...11'oclock loud...2'oclock very, very loud.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • deronb1
    edited August 2011
    stuwee wrote: »
    I am kinda the same way. All I wanted to know is what, for example -33db would be as an "o'clock" or percentage setting.
    This way I can know roughly how hard I am driving the new AVR to achieve a similar volume as compared to my old AVR.
    I guess what I am trying to say is that I have owned a number of different AVRs and the scale has been different for all of them. Some went from 0 to 100, some 0 to 60, some 0 to 80.
    That didnt really matter because I could always figure out approximately where the dial way. 50, 30 and 40 would be half way respectively.
    With this decible setting, I dont know how far the dial is up.
  • angelsfann02
    angelsfann02 Posts: 589
    edited August 2011
    I agree with others that say to use your ears as a guide. Whats loud to me may not be loud to you. Also,ever since I bought a separate amp, the volume on my Pioneer vsx-23thx doesn't get turned up so high. I used to dip into the -15 to -12dbs when I had the avr straight to my speakers. Now I dont usually stay in the -35 to -28 dbs range.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • BlueFox
    edited August 2011
    deronb1 wrote: »
    As mentioned above:
    "Buy a Radio Shack SPL meter to get an idea as to what sound pressure the various levels produce if you really want to know."
  • deronb1
    edited August 2011
    Thanks for the input guys. Either I am not asking the right question, or it cannot be answered.
    The SPL meter would mean nothing to me because I never used one on any of my old equipment. I guess I could hook up the old AVR and measure it too, record the results and compare it with the new one.
    I don't really care THAT much. Just wanted to know if there were any kind of conversion that would make this easy.
    With the Pioneer, it goes from -80 to +12. Halfway between these two numbers is -34. I have had the unit to this level a lot, and it is not near as loud as the old AVR at 50% (12 o'clock) whatever. So this leads me to believe that the increase is almost exponential as the volume is raised. Still doesn't tell me where the dial is.
    I see your points as to it really doesnt matter and its all relative anyway, but I would still like to know. I know it can be done because on the old Denon, I could switch back and forth between "relative" and "absolute". So whatever relative setting the Pioneer is on, there has to be an absolute value.
