Armour All fixed scratched CD
gmorris
gmorris Posts: 1,179
edited March 2004 in Music & Movies
I took one of my old Led Zeppelin CD's that was scratched, and "cleaned" the data side with Armour All.
This CD had a few spots that would skip. There were also some spots that were so bad, the player would get stuck on them, and would not continue playing. It would not shut off, it just got stuck.
The Armour All treatment worked 100%!! I was rather excited because I had "fixed" a previously unplayable CD. There was a slight change in sound where the skip had been, but it continued to play.
Has anyone else tried this?
Does anyone see or know of any reasons why this is a bad idea, i.e. can it damage the player?
Thoughts please....
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
  • HBombToo
    HBombToo Posts: 5,256
    edited March 2004
    when my daughter gets a gold of a cd and thrashes it I have found that soft scrub works very well to remove the abrasions.
    HBomb
    ***WAREMTAE***
  • Jstas
    Jstas Posts: 14,993
    edited March 2004
    The Armor All protect filled in the scratches. Your rubbing leveled off the surface or the CD and made the Armor All flush with the surface of the data side. That improved the quality of the reflected beam because the Armor All fixed the diffraction problem caused by the irregular surface of the scratch. If the CD's sensor cannot gather enough of the reflected laser beam, it will skip or stop playing because it lost the track of information. The bigger the skip, the less likely the CD player will be able to recover.
    Expert Moron Extraordinaire
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited March 2004
    I can't decide if the thread is a joke or not... :p
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2004
    My elbow was really sore, so I soaked it in some Armor All, and now I'm just like new!
  • gmorris
    edited March 2004
    No, this is not a joke....
    I was simply telling of my experience with using Armour All to fix up a scratched CD. Not much funny about that.
    I still would like opinions if this is a good or bad idea. It obviously does work, but are there any harmful side effects?
  • faster100
    faster100 Posts: 6,124
    edited March 2004
    possibly getting the armor all on the cd lens/eye what ever is in there, who knows..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • gidrah
    gidrah Posts: 3,049
    edited March 2004
    The "Armor All Teak" has been around for years. Not just to repair, but to improve. I've never tried it, but someday if I can find 2 indetical CDs and do an A/B.
    Make it Funky! :)
  • Jstas
    Jstas Posts: 14,993
    edited March 2004
    That is really the only problem I can think of with CD's. The Armor All, if you use too much, can get all over the inside of the CD player and gums things up and reduce performance. It's not going to hurt the CD plastic, not many chemicals that you would use to clean stuff will hurt the plastic. Just take care not to use to much when using it.
    An alternative is to use one of those Disc Doctors. They work well but they work through abrasion. So you don't want to have to use them too many times so take care of your media.
  • HBombToo
    edited March 2004
    I only use my disc doctor on very severe scratches.
    Hmmmmmmm, I'm thinking some wax might help here also:D
    HBomb
    ***WAREMTAE***
  • gmorris
    edited March 2004
    HBomb
    Not a bad idea. I'm thinking Meguirars Gold Class car wax. Maybe I'll give it a try.
    Another trick I read about was applying green ink to the inner & outer edges of the CD. The proposed reason this works is that the green ink absorbs any difracted red laser light (since green & red are complimentary colors).
    I've tried this now at home, with 10 or so CD's. I'm going to say that it works, and it works very well. So well, in fact, that I recommend anyone try it.
    I simply swiped a green Sharpie from the supply room at work, and that's all the supplies you need. All you do is apply the ink to the outer edge, and the inner edge of the hole. That's it.
    I am happy to report that this, in my system anyway, tames the harshness in the treble that is evident in many older recordings. It also has added much width & depth to the soundstage. These two areas are the most notable to me.
    Now, I'm sure someone out there is going to post saying that this is hogwash, that green ink on the edges will do nothing, and I'm full of poopy or whatever substance you like. All I have to say to them is: TRY IT. I thought it was B.S. when I first read it, so I went home & tried it for myself. Low and behold, it works like a champ.
  • HBombToo
    edited March 2004
    I read about that in the past and I see the logic in it.
    Green or Black should work equally the same, correct?
    HBomb
    ***WAREMTAE***
  • gmorris
    edited March 2004
    HBomb
    From the explanation in the article I read, only green will work due to the fact green is the complimentary color to red (the color of the laser) and will absorb the red laser light.
    http://www.soundstage.com/weaver04.htm
    http://www.soundstage.com/weaver06.htm
  • HBombToo
    edited March 2004
    Since black absorbs all color(thats why its black) then my point was it should also work?
    HBomb
    ***WAREMTAE***
  • gmorris
    edited March 2004
    HBombToo,
    I don't know. One thing I will say, when you apply the green Sharpie to the plastic, you can still see thru the plastic, it is just green now. Follow?
    I think if it were solid black, then perhaps there will be differences. I'm not sure. It is worth a try.
    The article also says that this trick will work better with lower quality CD players. I, as luck would have it, am a lower quality kind of guy. I'm standing by this trick and proclaiming it one of the best no cost improvements I've ever seen.
    Give it a try.
  • Airplay355
    Airplay355 Posts: 4,298
    edited March 2004
    i thought it was a joke too....armour all has been coming up alot lately lol
  • HBombToo
    edited March 2004
    I'll do it tonight.
    HBomb
    ***WAREMTAE***
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2004
    i will have to say i dont even use that stuff on my car i use mothers leather cleaner and other mothers products
  • PolkThug
    edited March 2004
    I'm calling BS on this one. See below.
    http://www.snopes2.com/music/media/marker.htm
    Regards,
    PolkThug
  • gmorris
    edited March 2004
    Regards,
    PolkThug
    Very good article. Very scientific sounding reasons why this doesn't work.
    All I have to say is: TRY IT. Try it for yourself. If, after you try it, and you still don't think it works, then call BS.
    I was just like you before I tried it, I didn't believe it either. Then I got a green Sharpie, took 2 minutes and colored the edges of a CD, and played it. I quickly changed my mind, it does improve the sound. In my system, I noticed a less harsh sounding treble, as well as a wider soundstage.
    Just try it out for Pete's sake.
