7.1 to 2 ch stereo
RodneyWoodford
I have a HK 254 and when I switch from 7.1 to 2 ch stereo the volume actually decreases , always taught it would increase . Shouldn't it increase or have I got something setup wrong. Thanks
I have the AVR354, and it depends on several factors. Did you run the Audyssey on your system? Audyssey could be applying EQ and Level adjustments, and you are only running 2 channels instead of 7... Also, depending on the 2 channel setting, you could be cutting your sub out of the mix too...
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
