Four Dollar Wire
rebuy
So I have the Onkyo and the rti4's ready to go except for a larger gauge wire.
We do have a Rat Shack which I've visited but I didn't want to buy Monster Inc.
I said to myself, "hey, go to the "True Value" hardware store and see if they have bulk wire to buy by the ft". So I did and they did, so we made the transaction and they kept the four dollars and I left with 20 feet of 16 gauge wire for the mains. Exciting isn't it?
When I bought the wire I noticed in the 16/2 mix that one of the jackets was slightly off color from the clear side and thought that is ok since it helps for polarity identification. How nice of the manufacturer to help by coloring the jacket. You know where we are going?
Well, it seems that one jacket is a green tinted because the wire on the inside of the jacket is corroded. Wasting away inside the true value hardware store and in my house. :eek:
You know, wire is wire, and this was a True Value
Thanks Paul
Good day
Thanks Paul
Good day
Post edited by rebuy on
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
riveting tale.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
I bought a spool of that wire. Good bang for your buck!!Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
If you're looking for cheap and NOT green, Monoprice is a good choice. If you want something that's a few notches above that, still reasonably priced and hand made? www.signalcable.com with a Polk discount to boot.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
monoprice is unbeatable for the price. cant imagine any other wire being better than this one - atleast better percieved sound quality
Four dollar wire, four dollar sound.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
four is a four letter word......:eek:Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
Monoprice wire turned green on me.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
To the original poster: IMO, skip that crap. Doro's suggestion about signal is good.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
President of Club Polk -
Amen to that gents.
4 buck wire ?? You would think new speakers deserve better.HT SYSTEM-
lsi 9's -
I only had to make 2, 10ft runs, Even though I did want larger gauge wire I was thinking New wire from the "True Value" hardware store would be ok since it is 16 gauge.
Remember I am in a very small town and choices are limited. Who would have thought that new wire was corroded on the spool?
I posted this experience to warn others about shopping for wires. -
all I'm going to say is you get what you pay for.
Corrosion is the main reason for oxygen free2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Oxygen free is not really oxygen freeIf you can't hear a difference, don't waste your money.
Very true. Here's a good article on cable composition:
http://www.audioholics.com/education/cables/exotic-materials-and-cable-constructionTV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
Here's a little bit of that article...read closely.
"We have cut into pieces of Belden coaxial cable twenty-five years old that have been used in radio transmission applications--and found them clean and bright, completely lacking any sign of oxidation."
Sure if you cut in the middle a cable,most will be free from oxidation because of the coating used, but it's not the middle that usually oxidizes, it's the ends,the connections. I also noticed he compares everything to broadcast cable where soundstage, presence, tone and weight have little to do with and not much of a concern broadcasting the 5 o'clock news.HT SYSTEM-
lsi 9's -
Interesting! I've, also, never seen anything but the ends corrode....even in cheap wiring. And I mean cheap!
What's described above must be some pretty badly coated copper that's been stored in a super hot humid space for a while!
But the other choices mentioned should address those problems.
MonoPrice is def the way to go for cheap 12 gauge:)Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier -
Monoprice has nothing to do with hi-fi. Basic listening, background music, sure. It will pass a signal, I'll give it that.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
haha ok thanks for that. All I'm getting from them are some Nanner prugs:)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
$4 sound isn't worth the effort of pushing the power switch.
cnh
I have had a power cable turn green. Not home audio though lol. It was roughly 5 years old and in one of my cars a long time ago. The entire thing all the way through was corroded and green. Tore it apart and it looked like bakingsoda inside the wire strands.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
you get what you pay for I guess. Going cheep is a short term solution.
Moral of the story, the OP had to rebuy his speaker wires.
Why not take advantage of MIT's B Stock sale? Looks like they still have some left.
http://www.mitcablesexpress.com/index.php?page=shop.browse&category_id=108&option=com_virtuemart&Itemid=14
wow, those are great deals!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
My Dad's 12 gauge he had hooked to RTA 12c's were green once, but that was mostly because he procrastinates in getting new equipment slash upgrades for any of his stuff, except for his Cd player... that he doesn't use. but yeah, he probably had the same 12 gauge he put on them when he first purchased them lol I'm inheriting those so I'll have an all 100% original pair lolHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Post #29 reported for spam..
4 dollar wire....5 dollar foot long....the worlds gone nuts I tell ya.HT SYSTEM-
lsi 9's -
Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
