best way to remove dried Gorilla grip...
nooshinjohn
without damaging paint. Any Ideas?
Post edited by nooshinjohn on
Do you mean the glue?Political Correctness'.........defined
President of Club Polk -
Yessir... that's the stuff.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Ok, it's a polyurethane based product that cures with moisture. Absolutely horrible glue. The only way I know to remove it is to scrape or peel. If it's on a non-porous surface try to lift an outer edge with something like an Exacto knife or razor blade. Then carefully peel it off.Political Correctness'.........defined
That's the only way I have been able to remove it. Razor blade it or chisel it. In one case, I sanded it but I don't think that will work for you in your application. Gotta remember this for the next project...this glue expands as it cures, so less is more. Also, the removal of the bulk of excess glue is messy but best done just before hardening [when it has the consistency of a booger or soft rubber band]. This will make the excess glue removal using the razor blade easier.
If this is for your amplifier, cut first around or at the aluminum plate down to the paint itself. You may try to angle the blade to where the blade goes underneath the plate, hiding any potential and likely scratches from the blade. Once the bulk of the glue has been separated from the aluminum and their is no connection between the glue that you want to remain and the glue you want to remove, then carefully lift the outer edge and remove.
Make sure the blade is brand new and that it has a reinforced side. You may want to try to add some WD-40 to the blade prior to prying. Also, keep the blade as close to the paint as possible [like at a 3-4 degree angle when prying]. One more thing. Take masking tape and apply it as close to [but not touching] the glue removal area as possible to prevent any further scratching.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
nooshinjohn wrote: »Thanks!.. I am mounting the side panels
Tell me you didn't use Gorilla glue on your amps.Political Correctness'.........defined
Jesse, I am hoping not but that's the first thing that came to mind this morning.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
heavy duty double sided tape and silicone for the side panels... no Gorilla glue.
I used the glue on a curio cabinet that was slightly damaged when we moved.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
*wipes brow*~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Whoa!....Use citrus based cleaner if the base surface will allow. I cant guarantee for your application but its worked for me in the past. Good luck!
That's almost like Bondo so if you could sand it to shape maybe?Too much **** to list....
