Top Mount vs. Bottom Mount dimensions...quick help needed
AsSiMiLaTeD
What is the difference between the top mount and bottom mount dimensions???
Top = Mounted above the mounting surface
Bottom = Mounted from below the mounting surface.
It is usually about the size of a grill or frame...1/4 - 3/4 inch max is what I have seen.
