Am I crazy or is this a brilliant idea?
    EndersShadow Posts: 17,723
    edited August 2011
    I dont need the line driver as the USB to RCA DAC will be used to feed the full signal into the amps just like the CD player does now. Then I would use the 125.2's pre-outs to send that same full signal to the 1200D sub amp. Crossover settings for high and low pass would be set at the amps rather than the HU though....
