Help...can I place my SVS underneath my TV?
doggie750
doggie750 Posts: 1,160
edited August 2011 in Electronics
Help on this guys, will build enclosures cabinet to look nice but concern on the TV's integrity with the SVS monster.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • doggie750
    edited August 2011
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • thsmith
    thsmith Posts: 6,082
    edited August 2011
    I would not not only because it would not sound good but it will generate unwanted vibration to your electronic gear.
    Of course this is just my opinion.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    Why did you link to this thread?
    I would not for the reasons stated above.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited August 2011
    Joe08867 wrote: »
    You mean I've been clicking the same link for the past hour??? :eek::confused:
    Tony M Posts: 11,623
    edited August 2011
    I've never heard of a sub under a TV. Beside and below with SMALL subs, yes. Your talking about an SVS .....
    Thunder under= broken electronics like thsmith said.:frown:
  • inson71
    inson71 Posts: 90
    edited August 2011
    The answer to your question is yes, but it will take some careful planning. Where are you placing your tv in relation to the room? I assume by enclosure you mean around the subwoofer? If so, you will need some dynamat or similar product. I have been running my SVS PB12plus under my tv for two years with no problems and good results. In the long run probably not the most ideal location, but if you have space restraints it can be done with careful planning.
    Onkyo Pr-sc 5509
    Parasound 2250/Parasound 5125
    SVS PB 12 Plus
    Denon DBP-2012 Bluray
    Polk RTI 8, CSI 3, 4 FXI 3
    Sony 55" LCD
    pitdogg2 Posts: 27,050
    edited August 2011
    mdaudioguy wrote: »
    nope he has 3 of the same going at the same time
  • inson71
    inson71 Posts: 90
    edited August 2011
    inson71 wrote: »
    Here are a couple pics.
    Onkyo Pr-sc 5509
    SVS PB 12 Plus
    Sony 55" LCD
  • mdaudioguy
    edited August 2011
    inson71 wrote: »
    ^^^ Neat, clean, custom fit! Nice! :smile:
  • inson71
    inson71 Posts: 90
    edited August 2011
    mdaudioguy wrote: »
    Thanks!
    Onkyo Pr-sc 5509
    SVS PB 12 Plus
    Sony 55" LCD
