Wall mounted bookshelfs? pics anyone
Just wanted to see if anyone had pictures of Tsi100 or Rti a1 wall mounted near there tv. Searched on google and couldn't find much .
Post edited by 1QWK510 on
You'll want you pick up a set of BTech 77 wall mounts with those. They will allow you better speaker placement and position should you need to angle them more/less toward the listening position. See my showcase and you will see a pair of RTi4s paired with the BTech.
http://www.amazon.com/Rocelco-B-Tech-BT77-Ultragrip-Loudspeaker/dp/B004DCAOHKShoot the jumper.....................BALLIN.............!!!!!
This might also be another option Pinpoint AM40B:
http://www.amazon.com/Pinpoint-Universal-Bookshelf-Speaker-Mount/dp/B002UV03MW/ref=pd_cp_e_1
I used them to mount some RT25i in my kitchen. A not so good picture can be found in this thread.
http://www.polkaudio.com/forums/showthread.php?t=117621 -
BTech77 (now pinpoint) using RTiA3s:
http://erikt.cts.com/Pictures/hometheater/home-theater-valor.JPG
Thanks Eric that's what I was looking for. I think I'm gonna go with the Tsi100's and use the built in wall mount in front. The bottom of my tv is at 48" (ear level). What did u use for the center channel mount? I'm think of mounting it above the tv if I can find a way to angle it down. The cs10 will sit almost flush with the top of my tv on the tilt mount.
I used the B-Tech B15 center mount:
http://www.amazon.com/B-Tech-Center-Channel-Speaker-Bracket/dp/B0002YCKLQ
Now called the pinpoint.
The easiest way to mount the TSi 100 is to use the bracket on the back - but you won't be able to angle the speaker up/down or left/right and the rear vented port will be right up against the wall.
Cheers,
Erik
