Speaker (stand) spikes
pjshelley
pjshelley Posts: 15
edited March 2004 in Speakers
Help, please - anybody!
Does anyone know where I can get a set of 8 metal (or acrylic) speaker stand spikes (a.k.a. toes, cones, or whatever the heck these things are called?!?!?) for a pair of SDA 2.3's? My fingers are getting numb from typing search strings on Yahoo, Google, Altavista, etc. !
:confused:
"Ring them bells that still can ring...forget your perfect offering...there is a crack, a crack in everything...that's how the light get's in." - L. Cohen
Post edited by pjshelley on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2004
    www.oregondv.com Paul carries top notch stuff, and is a Polk Forum supporter.
    SDA's have 1/4 - 20 spikes.
  • pjshelley
    pjshelley Posts: 15
    edited March 2004
    Thanks, Doro!
    I had found the http://www.oregondv.com/ website, but what threw me off, was that all spikes seemed to have protruding threads to be inserted into the woodwork, like when you're DIY-ing it. I guess if Paul is a supporter of Polk and our forum, he may have the kind you can just slip underneath the speaker. I'll send him an email. Thanks again.
    BTW, in the mean time I have found the following:
    http://www.kalapanadesigns.com/spikes.htm
    and
    http://www.cybermarket.co.uk/ishop/923/shopscr251.html
    Any comments?
  • dorokusai
    edited March 2004
    Spikes are basically spikes.
    I deal with Paul because of his support of the Polk forum, and that's good enough for me. The threads are removeable, and you can either use an existing insert, install the insert provided, or "glue" them onto your gear.
