just upgraded to lsi15 for music/ht and snell xa1900 center
anyone have experience with snell xa1900 thx center speaker , anyone heard or tried it yet, i am going to be using a ma700 4ohm 300 watt to power it up.
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
If you have LSi15's for the front speakers, you will want to use a Polk LSiC for the center. If you use a different center channel, your front stage will not match. The speakers will sound different, so your sound will change as it pans from left to center to right. This is something that is very noticeable to me and many others.
While that can be true, it is not always true. I have 4 LSi15s, and was using an LSiC. I upgraded the LSiC to a PSB Synchrony One Center, and it blends right in. No issues at all. I did not even have to change the AVR SPL settings for it to match with the other speakers. However, it is a big improvement over the LSiC in terms of 'bigger' and better sound from the center.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
i had a lsic , did not like it for movies, not clear , great on music, i had a boston acoustics 325c,clear on voices ,but not as good with music, so i am trying this speaker snell xa1900 for home theather. i got this b**chin amp was rebuilt by rolland at car, new poly capacitors, rebuilt to spec . new amp is gonna rock those lsi15 ,600watt 4ohm. but i want to know who had experience with snell, iam waiting on it to arrive,gonna run ma700 amp 300watt 4ohm. so i have rti12's but replace with lsi15 for music , when only running lsi15 .snell is when i watch movies etc.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
power.c-bpt cpc/ps.soloist ci. -
I keep hearing people say that, but I honestly do not understand why. My LSiC is crystal clear, on both movies and music. It certainly keep up with the rest of my LSi system, and of course blends perfectly.i had a lsic , did not like it for movies, not clear
Of course, it depends on the movie's soundtrack too. Some are just mastered poorly, and that is not the fault of the speaker in any way. -
+1 to Beef Jerky statements.
That said, I would consider adding another LSiC if I were to move my theatre into a larger room.Do you hear that buzzing noise?
Mine was to, but I felt it was not up to par with the LSi 15 speakers. Upgrading my LSiC to the PSB was one of my better HT upgrades. Right up there with adding the Sunfire TGA-5400 amp, MIT interconnects, and Mapleshade Golden Helix speaker wire. I might be upgrading my 2 front LSi15s at some time in the future to PSB Synchrony One towers, but that will be after I upgrade my two channel speakers. Then the PSBs will be free for the move to HT.Lumin X1 file player, Westminster Labs interconnect cable
What is the cost for a PSB Synchrony One Center upgraded?Equipment
Panasonic TC-P54S2 Plasma
Scientific Atlanta DVR
ONKYO TX-SR705 AVR Pre/Pro
Outlaw 7125 7 CH Power Amplifier
Toshiba A2 HD-DVd
Panasonic BD-30
Harmony 550 remote control
LSi9 ( Mains )
LSiC ( Center )
PSB Ambient 2 Dipoles
SVS 20-39 PCI Subwoofer -
It will be interesting to see if this complaint about the LSIC goes away with the new one coming out.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Maybe it's possible this is due to gear and/or wires?! Yours may be a good match, and maybe some of the others are using stuff that isn't a good fit for lsi's? What gear are you running your lsi's with, including the center?
Of course speaker placement is also a big deal since lsic is not that big of a speaker... I found this to be very important with the cs2. When I had it too low under the tv, it was hard to understand dialogue.
Just from swaping out gear and wires and changing speaker location, I am finding there are quiet a few variables that can make a difference.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
My system is as follows:
Pioneer VSX-21TXH AVR
3x Marantz MA500 monoblocks for front sound stage
1x LSiC
2x LSi9 for front left and right
4x LSi7 for surround and surround back
12 gauge low-voltage-lighting cable from Home Depot with Monoprice banana plugs for the speaker cables
Various brands of good quality interconnects
I'd like to note that when running the LSiC off the AVR, it was still clear, I just had to watch the volume.
I have the LSiC placed above my Samsung 52" LCD angled down to ear level. -
AHA!
Somehow I bet some of the poeple who complain about clarity of the lsic have it sitting UNDER the tv, with possibly a table or other obstructions between the speaker and the listening position... :rolleyes:
Also, marantz gear tends to be very neutral/natural. I saw an improvement in clarity of sound vs my onkyo when I got my marantz sr7002. Glad you posted, kind of confirms my suspicion.
It all makes a difference
Part of the issue the OP was probably having is all the different amplifiers powering things. I never liked mixing and matching amps for the same system. The word is Synergy. I can't imagine how much Synergy there is with Carver, Fosgate Audionics and Soundstream all on the same system.
That being said I heard the LSIC was a bit of a power hog. I don't know if it is true but having heard one I can't imagine issues with clarity. -
If I was to choose a weak link in the previous LSI lineup it would most certainly be the LSiC. The cascaded design is flawed and it just doesn't have enough **** for me in regards to center channels. It should have used a traditional array, been larger or used an additional tweeter for a wider dispersion if the form factor was critical.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Mark, have they changed the design of the CC in the new series?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
well lsi15's rock with carver amp, got a parasound 2250 for them, well i was pushing 450 watt 4ohm thru a carver pm 900 , i did not test on new amps. well i believe the snell xa1900 should blow it out of the water .receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
That's not a coherent sentence...
Are you using the parasound or the carver now?
I am lost
Lietuvis91 wrote: »That's not a coherent sentence...
I am lost
I can't follow him on that one either.
I am lost
ok, I was using carver pm 1.5 rebuilt but sold it yesterday and came up on a parasound 2250 to drive the lsi15. I am waiting on the snell xa1900 , will post video asap . i have another amp for my center speaker fosgate 4200 450 4ohm bridge x2 50 amp current per channel, i have that hookup to the lsi15, and they sing. so no one has answer my question, who has used a snell center speaker ,like a xa1900.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
pic of lsi15 , parasound 2250 driving them, snell getting drove by fosgate , and not pictured is rear owm3 and klispch rs7's btw:the snell xa1900 is HUGE ,lol.sounds great though.
Dude, your setup is all over the place.
Three completely different style amps, Three different speaker manufacturers and your worried about how there gonna sound?
I could only imagine how a Horned dual tweetered center is going to sound against the LSI's. Wow, I have nothing.
I have heard Snell and they make nice stuff I just can't imagine the timbre match will be there at all. Snell are way bright in my opinion. -
actually calibrated all the sound to be equal in db , for home theater sounds great, when i listen to music , i use only the lsi15, working on getting another parasound for my center.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
I understand the db and eq levels matching I am talking about the material and build of each comparatively. The Tweeters in the LSI's don't match the Snell and Where do you have the Klipsch? They don't match anything either. :eek:
I hope it sounds good but on paper it does not compute.
I think finding another Parasound would help things a lot. They have a very nice sound and you would have some form of uniformity to the system. :cool: -
i have it on the wall on the sides,the rs7 klipsch. i do agree on parasound , iam working hard on getting rid of my da-2 amp.they actually sound good,i have the 2250 parasound on the lsi15,clear as the sky.i have the fosgate on the snell , clear also , but it is a little older and not ultra 2 specs.yeah it sounds good,just want all parasound if i can lol.I understand the db and eq levels matching I am talking about the material and build of each comparatively. The Tweeters in the LSI's don't match the Snell and Where do you have the Klipsch? They don't match anything either. :eek:
I think finding another Parasound would help things a lot. They have a very nice sound and you would have some form of uniformity to the system. :cool:receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
Try experimenting with those 15's. I would widen them out by about a foot and a half on each side and bring them forward at least another 6 inches to a foot with a slight toe in. They seem to me anyway, too close together with that monster center.HT SYSTEM-
lsi 9's -
alright , upgraded to another parasound 1200ii, got rid of soundstream,i plan on using the 1200ii for my center speaker, trying to get rid of my beaut fosgate amp for another parasound 5 ch amp for surrounds.i now have parasound 2250 for lsi15 , parasound 1200ii for center , using fosgate 4200 for surrounds, but want to match .looking at parasound 1205a for surrounds.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
Have you tried your Fosgate Audionics 4200 (it is a 4200 right?) on the LSi's yet? It's an older amp but from my experience with this amp, it's better designed and better build then most of todays top dollar units and it has the THX certs from before there ever was such a thing as the ULTRA this and SELECT that....THX ratings. I'm using the 4 channels of the fosgate audionics 4200 to bi-amp my martin logan SL3's with excellent results and I've tried many of the so called THX Ultra... certified units. Open up the hood of the 4200 and you'll see what I'm talking about. You could even try bridging 4 channels into 2 channels for more punch on the LSi's and see how that sounds.2 - Fosgate Audionics 4200's
Denon AVR2802
Martin Logan SL3 - Front mains
Polk CS350LS - Center
Infinity Primus P362 - Rear Surrounds
Infinity Reference 2000.3 - Sides
Martin Logan Abyss - Sub
Wadia WT 3200 Reference Transport
Rotel RCD-1072 CD/HDCD
Sony PS3 - BluRay
Monarchy Audio Model 33 DAC/Preamp
Monarchy Audio DIP Classic
Monarchy Audio DIP 24/96
Ming-Da MC-7R Tube Preamp
Grant Fidelity B-283 Tube Processor
Sony 52" XBR4
