bridging a parasound 2125 one side the other pair for surrounds
deseroner
i was wondering if i can bridge only one side a, and the other b just for my surrounds, i can do this with my fosgate 4200 .
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
If your asking if you can bridge one side A and leave the other side B stereo? Yes, but you can only use one side at a time. So you will either be using the bridged channel or the stereo channel not both at the same time.
It is a two channel amp not a 4 channel amp.
PS if you try to use both you will burn up that amp.
