Setting crossover frequency on avr
running a new setup rti8's a6 & rti6's
When setting crossover frequency in the avr should i set the crossover "at" "above" or "below" the speakers specs?
Post edited by jojomgee on
You want to set the crossover above the lower -3db lower frequency response limit of the speaker. Some say you should set the crossover as high as 1 octave above the lower -3db limit. If it were me, I would probably set the crossover no lower than 60Hz for the RTi8, and no lower than 80Hz for the CSi A6 and RTi6. If you can't set a separate crossover point for each channel/pair, my suggestion would be to set it at 80Hz.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
i can set separate for each channel....
im not exactly understanding your explanation though....i understand what the -3db limit is but what would "1 octave above " mean?
the -3db on the 8's is 40hz overall 30-27
6's is 50hz overall 40-27
A6 is 55hz overall 45-27
is 1octave basically 20-30 hz? -
1 octave up = frequency x2. Therefore, one octave above 40Hz would be 80Hz. 50Hz+1 octave=100Hz, etc.
1 octave down = frequency/2. Therefore, one octave below 40Hz would be 20Hz. 50Hz-1 octave=25Hz, etc.
I personally think, while a good rule of thumb, using the octave rule can a bit overkill, therefore my suggestions were a bit more conservative. You do want to give yourself some room between -3db and the crossover though, to keep the frequency response as flat as possible in that band.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
I normally use a half-octave. A full octave almost never sounds as good, and kinda' negates the point of having floor-standers. With the slope of the crossover used in AVRs, a half-octave above the -3dB point normally gives you a very smooth transition because the in-room performance of the speaker will typically be lower than the -3dB point anyway.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
One more question....i use the rti6's for rears..if i set the crossover to lets say "60hz" I will get more bass from rears... right?
The real question to ask you is: What do you listen to more - movies or music? What does the AVR set the crossovers at?My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
90% movies
and i dont understand your second question....i thought i manually set the crossovers -
80Hz & set to small.
