Stripping the vinyl veneer off monitor 10's
athos56
athos56 Posts: 14
edited July 2011 in DIY, Mods & Tweaks
Anybody have any ideas on stripping the vinyl veneer off of some monitor 10's? I experimented on an extra 5jr I had and it seems like a chore with just a razor blade.
Post edited by athos56 on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited December 2006
    You'll need a heat gun to release the adhesive. Good luck!
  • athos56
    athos56 Posts: 14
    ahh a heatgun, and then it will just peel off or will some razor work still be nessesary? Thanks
    F1nut Posts: 51,886
    Heat a little area at a time, peel back the loose stuff and repeat until done. No razor needed.
  • ben62670
    ben62670 Posts: 15,969
    ditto ditto ditto...
    let the heat do the work... if the vinyl tears a razor blade does help get you going again
    I personally like to get the vinyl nice and soft.. start with a corner away from you and pull the vinyl back over itself... I suck at putting things into words basically what i am trying to convey is that the finish sides of the vinyl almost touch as you pull it off. Avoid the temptation of rocking the vinyl side to side it can stretch the material and make it more prone to rip. take your time and keep it warm. a hairdryer will work if its a hot one. you can even pre heat the vinyl with a clothes iron to get it going .
    Good luck let us know how you made out.
    Ben
    Ben
  • Crispycircuit
    Crispycircuit Posts: 49
    edited January 2007
    I'm very curious on how this goes. Are you recovering, painting, ??? I hope the adheasive comes off.... Keep us posted.....
  • wanders
    wanders Posts: 15
    edited July 2011
    I've had good luck veneering a couple of pieces, recently a Pioneer PL-570 turntable. Used paper backed veneer and heat activated adhesive. On the Pioneer the vinyl peeled off fairly easily; hard work but no heat needed.
    I'm now thinking of veneering a set of Monitor 10s. Most advice calls for heating and stripping the existing vinyl.
    Question, what's wrong with just sanding the existing vinyl to get adhesion then putting the wood veneer over the vinyl?
    Would appreciate opinions.
    F1nut Posts: 51,886
    edited July 2011
    Bad idea. The glues used for wood veneer are not designed to adhere to plastics.
  • wanders
    wanders Posts: 15
    edited July 2011
    Thanks for the advice, F1. Also, ironing on new veneer could heat and loosen the underlying vinyl if it's left on.
    Question: How tough is it stripping the vinyl using the heat gun? And, how much glue residue is left to deal with?
    F1nut Posts: 51,886
    edited July 2011
    See post #4.
    Not much, scuff sanding should be all that's needed.
  • saemark30
    saemark30 Posts: 146
    edited July 2011
    Does your vinyl veneer look like artificial rosewood?
    Mime scratches way too easily.
    What type of veneer is suitable or recommended?
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    lostsgtlfacph reported
    How do you even say that?
  • wanders
    wanders Posts: 15
    edited July 2011
    saemark30 wrote: »
    I think mine are dark walnut; I've seen pictures of Polk's rosewood vinyl veneer and it looks more fake than the walnut. Choice of veneer is up to your taste. Walnut or teak will take oil finishes which you could do yourself. Rosewood veneer is much more expensive than walnut; also, it is very oily and needs a high gloss, spray, lacquer finish. It's tough to achieve satisfactory results with a spray can, that's best left to a professional.
    There is some veneering information on this forum; and lots of information on the AudioKarma forum.
