A Clutch of Klipsch/$100
George Grand
George Grand Posts: 12,258
edited July 2011 in For Sale (FS) Classifieds
LOCAL PICK-UP ONLY
A pair of Klipsch KM2 monitors, a ported, 6" two-way with dome tweeters not horns. Black cabs quite presentable, perfect grilles with badges.
One Klipsch center channel speaker that appears to perfectly match the monitors above. Looks like two 5 1/4 inch woofs with a dome tweet in the middle. Presentable black cab, no problem grille.
One pair Klipsch Tangent 1000 monitors, a ported, 5 1/4" two-way with dome tweets not horns, in presentable black cabs, one tiny flaw in one grille, badges intact.
$100 for the lot.
Post edited by George Grand on
  • Gempler
    Gempler Posts: 308
    edited July 2011
    Some info on the KM-2 from Klispch's site...
    8a12b43b4dddcf73ea42e1e1493a1178.jpg?
    The two-way KM-2 bookshelf loudspeaker was first introduced in 1994 and manufactured by Klipsch until 1997 specifically for U.S. Armed Forces distribution around the world. This line was the last Klipsch line specifically made for our U.S. Armed Forces overseas.
    SPECIFICATIONS
    ■BUILT FROM: 1994
    ■BUILT UNTIL: 1997
    ■DIMENSIONS: 13" (33cm) x 9.25" (23.5cm) x 9.25" (23.5cm)
    ■ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
    ■ENCLOSURE TYPE: Bass reflex via rear-mounted port
    ■FINISHES: Black vinyl
    ■FREQUENCY RESPONSE: 50Hz-20kHz(+-)3dB
    ■HIGH FREQUENCY HORN: Exponential Cone
    ■NOMINAL IMPEDANCE: 8 ohms
    ■POWER HANDLING: 50 watts maximum continuous (200 watts peak)
    ■SENSITIVITY: 90dB @ 1watt/1meter
    ■TWEETER: K-89-K 1" (2.54cm) Polymer dome compression driver
    ■WEIGHT: 15 lbs. (6.8kg)
    ■WOOFER: K-1007-K 6.5" (16.51cm) ICG cone
    and the tangent t1000 (closest model to match the above description)...
    9cec5a14c8fe24ae3ded767bba49fe50.jpg?
    The two-way Tangent Series Tangent T-1000 bookshelf loudspeaker was first introduced in 1993 and manufactured by Klipsch until 1994. While no longer in production Tangent T-1000 model loudspeakers are still owned and listened to by Klipsch fans around the world as part of two-channel audio and home theater surround sound systems.
    SPECIFICATIONS
    ■BUILT FROM: 1993
    ■BUILT UNTIL: 1994
    ■DIMENSIONS: 11.9" (30.2cm) x 8.5" (21.6cm) x 7" (17.8cm)
    ■FINISHES: Matte-finish Black vinyl
    ■FREQUENCY RESPONSE: 60Hz-20kHz(+-)3dB
    ■HIGH FREQUENCY HORN: Dhorm
    ■POWER HANDLING: 75 watts maximum continuous (250 watts peak)
    ■SENSITIVITY: 91dB @ 1watt/1meter
    ■TWEETER: K-88-KV 1" (2.54cm) Phenolic dome
    ■WEIGHT: 10.5 lbs. (4.8kg)
    ■WOOFER: K-1015-KV 5.25" (13.34cm) Poly cone
    no idea what the center channel is but you can polk arround www.klipsch.com and probably figure it out.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2011
    Rubbish. Someone should pick these up just to save the forum from further posts on the subject. T. Rome, how dare you!
  • George Grand
    edited July 2011
    I got a bad Sunkist Orange monkey on my back.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    Kool Aid man has always been my nemesis.
  • George Grand
    edited July 2011
    dorokusai wrote: »
    Been there. I started out on Fizzies. Then the straws that made your milk either chocolate or strawberry. Tang. A long, slippery slope.
    mhardy6647 Posts: 34,929
    edited July 2011
    oh, good heavens, George... Tang?! You know what that stuff did to the astronauts.
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2011
    I went about 40 years and I finally put two and two together that "Tang" is not an orange juice. It is short for Tangerine.
    edited July 2011
    speaking of Tang... our daughter's father-in-law flew on a Space Shuttle mission...
    http://en.wikipedia.org/wiki/Jay_C._Buckey
    I haven't asked him about Tang, though...
  • RuSsMaN
    edited July 2011
    I prefer Poon-tang.
  • George Grand
    edited July 2011
    RuSsMaN wrote: »
    I prefer Poon-tang.
    Shame it's always bare shelves by the time you get there.
  • RuSsMaN
    edited July 2011
    It's always bare. I know you Jeresy boys like to keep it real "70's" down there, you like your hair.
    edited July 2011
    RuSsMaN wrote: »
    I prefer Poon-tang.
    Great regular flavor: seafood.
