Custom built Cabinet (SDA) ??
2
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    Then specifically which model are you guessing has the pitched drivers as there are many different models mentioned in this thread.
    Also since clearly its not a common known attribute and thus not critical to the SDA effect (or it would be well known and documented in all models) I don't suppose its going to be too critical to a home made set? eh?
    Too much **** to list....
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    OK the article is talking about the acoustic centers of the drivers being offset by 20 degrees.The acoustic center can be roughly aproximated as where the voice coil meets the cone or dome so the acoustic center of the midbass will be behind the tweeters.Mounting the midbass units at a slight 3-4 degree angle would IMO have an insignificant effect since it's only operating up to 2-2.5 khz.
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    So let me see if I understand you FTGV.
    If you draw an isosceles triangle from left to right to sweet spot the angle from the sweet spot to the driver center is 3 or 4 degrees different then that to the tweeter center?
    If thats the case I'd believe that. But to purposefully manufacture a 3-4 degree angle in the cabinets.....not so much.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    Because of tweeters acoustic center being further forward than that of the midbass's,mounting the tweeter outside of the stereo array drivers adds enough delay so that the sound of the tweet and midbass arrive to the ear at the same time.The resulting lobe is claimed to be angled inward at 20 degrees.Thus the recommendation for no toe in as it would increase this angle of radiation inward too much.
    If the drivers are flush mounted how can they possibly be angled to any degree unless it was the entire baffle.?Like I said previously IMO 3-4 degree angling of the midbass drivers would have little effect IMO.
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    I get what your saying about the tweeter not having a center of radiation like a driver.
    What I am saying about the 3-4 degree difference between the center of the tweet and the center of the driver arrays is if you draw a line vertical from the floor through the center of the drivers and then one through the center of the tweeters then draw a line from that center to the sweet spot the drivers would be about 3-4 degrees left or right of the tweeter center.
    That's about the best idea I have for an understanding or explanation of what Heiney is saying. Though its still a big difference from that to having a pitch machined into the cabinet.
    F1nut Posts: 51,710
    edited July 2011
    The internal volume would be the same as the 1.2tl's and the cabinet height would be the same as the 2.3tl's, only it would be deeper.
    I'm thinking an increase in depth would affect the passive radiator response, but I could be talking out of my a$$.
    F1nut Posts: 51,710
    edited July 2011
    Yeah, there's no pitch to the driver mounts.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    If internal volume is the same and box isn't over damped the PR response should'nt be effected.
    nooshinjohn Posts: 25,894
    edited July 2011
    I would think that internal volume has more of an impact on the passive than the distance between it and the back wall of the cabinet.
    F1nut Posts: 51,710
    edited July 2011
    It seems to me that the sound waves would have to travel farther, therefore slowing down the PR response.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    The tweet and mid bass both have an acoustic center.Since it is approximately where the voicecoil meets the cone or dome is much further forward on the tweeter.
    edited July 2011
    While we are discussing the re-invention of the wheel here, would it be at all possible to incorporate ribbon tweeters into the mix?
    F1nut Posts: 51,710
    edited July 2011
    Sure, but then you're into the world of having a frankenpolk.
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    I would think the PR is moved by air volume not sound waves in a semi sealed cabinet.
    edited July 2011
    building entirely new cabinets already puts us there imho.:cool:
    heiney9 Posts: 25,427
    edited July 2011
    Yeah, well I read it somewhere over the years and stuck it in my long term memory. Just can't recall where. Anyway that's the least critical of all the baffle properties one needs to consider and be exactly precise about if you are going to recreate a new cabinet. Internal and external dimensions are a piece of cake. Proper mounting of the drivers is critical to maximize SDA properties. However there is enough technical info out there to get it done.
    Just found my Compendium and reread the original SDA white paper, fascinating read and explains SDA the best. Some may have to look beyond the math calculations so you aren't side tracked. The concept and execution theory are right there for the reading.
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    What I'm taking here is you are speaking of a vertical 20 degree off set,no?
    I am speaking of a horizontal off set of 3-4 degrees.
    edited July 2011
    It's recreation of the original, not re-inventing the wheel.
    BIG difference.
    Toolfan66 Posts: 18,011
    edited July 2011
    Going off track for just a second since internal volume was mentioned, Now I now it is important but the CRS+'s and 2B's have the same crossovers/drivers and tweeters. the only thing different is the PR and "internal volume". how is it that it seems this rule does not apply here?? what am I missing??
    edited July 2011
    SDA1C wrote: »
    No, read carefully
    thus the effective axis of radiation, is shifted by an angle of 20* toward the listener.
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    How can you have a center of radiation and a 20* shifted axis?
    edited July 2011
    heiney9 wrote: »
    BIG difference.
    Correct!!!
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    As I pointed out it's 20 deg inward meaning horizontally.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    The angle created by having the woofers acoustic center physically further back than the tweeters angles the main lobe toward the listener.Visualize the resulting angle when drawing a line from the center of the midbass's dust cap to the dome of the tweeter. .
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    FTGV wrote: »
    As I pointed out it's 20 deg inward horizontally.
    Exactly! so then the tweeter isn't effectively radiating from center. And with that understanding the 3 degree would be between the tweeter offset and the stereo driver array and the 4 degree would correspond to the SDA array.
    I'm just trying to figure what Heiney was reading to think there was a planar difference. The reason being...I have some literature somewhere that speaks of a 3-4 degree difference as well but I believe it was based variable on the actual distance between speaker front and sweet spot
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    FTGV wrote: »
    I'm with ya on that one bro. It's not the plane I am speaking of though.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    SDA1C wrote: »
    Cool,I was just responding to the ? above.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    SDA1C wrote: »
    The optimum axis would likely be with ears at the mid point between the midbass and tweet. with a small window of a few degrees in either direction where response is not altered greatly.Is that what you are alluding to?
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    All things considered this project has me thinking. I have another facet to throw into the mix though. How thick would the steel have to be t o eliminate any resonance. For some reason I have this picture of a set made of polished stainless or possibly a powder coated option. My first thought would be to start in the 1/2" plate and go thicker from there. on thing is for sure. You wouldn't need to back up with a set of Larrys amazing rings lol
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    FTGV wrote: »
    Sort of. If you draw a line from your forehead (that is in the sweet spot) to the center of the stereo arra ,tweet and sda array the line on the stereo array would be 3 degrees off of canter and the sda array would be 4 degrees in the opposite direction off center.
