Loudness switch... can I live without it?
m1aman
Thinking about going from a vintage Pioneer receiver with a loudness switch to a new Cambridge system without one. Those of you who have had to make the transition... do you find it annoying? I fear I will find myself constantly fiddling with the controls without my beloved loudness switch. Is the loudness switch just a dated feature?
Post edited by m1aman on
Unless you listen to a lot of LOW volume music in the background you won't miss a thing and you'll hear a lot more!
As I type this I am listening to a two channel system with a Nakamichi pre-amp that has absolutely NO tone controls of any kind. It sounds great!
My integrated tube amp is the same...no tone controls....everything is flat but lush and warm.
And at least the Cambridge has tone controls, you can adjust at your whim?
Free yourself. Live without.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
I listen to both low-level and loud music. I personally like a properly designed loudness switch/button like B&K, NAD, and HK have on many of their units. If done correctly, it fades as the volume increases which suposedly mimics our hearing ability.
I don't miss loudness compensation, tone controls, balance control, nor an active preamp. Less is more, sometimes.
Yeah, what the Hell, just fix the sound with a long parade of cable changes instead of the controls the engineers specifically designed for that purpose. Some of the minimalist, die-hards on here who shun everything but a volume knob really crack me up ! I wonder if any of em remove the brakes from their cars??:biggrin: FWIW, a boost to the bass control can somewhat mimic the loudness feature.
I don't much "believe" in cables... but I do agree they can be used as a very expensive form of tone control.
I don' 'roll' tubes, much, either. I just use pretty good stuff that I like... not even terribly expensive stuff: one could - fairly easily - spend more on a set of "interconnects" than I have invested in the whole system in the living room. It sounds good loud. It sounds good soft. -
I gotta admit I don't know anything about such things. All I have ever had were receivers with a loudness control. The Cambridge setup will be my first separates ever. I wasn't even aware there were systems with no tone controls.
It's amazing how little you know about this hobby.Political Correctness'.........defined
President of Club Polk -
It's even more amazing how much you're convinced you do know. :biggrin: For me it's not a hobby or an obsession, merely the means to an end that is music reproduction that is acceptable/ pleasing to my ears. I do not seek recognition, status or title, just good music.:rolleyes: -
Loudness control=SatanSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Precisely why I put gdb on the iList months ago, Jess. The boy's got issues.
Hello to you too, how's your bud H.I. doing, Hmmmm ????? You kids really are a genuine scream. Isn't there anything else in your life, do you ever get "lucky" with another human? Better sweeten up towards me haole, I'm going to be in yer neighborhood very soon!:eek: -
How do you see my offerings if I am, in fact, on your prestigious ignore list?? You peeking ?:biggrin: -
The only loudness control remotely useful IMO is of the variable sort as that utilized in a number of Yamaha's products over the years..
We all peek, it's human nature!! :biggrin:
I only use the loudness switch in low level situ's.
I Love Yamaha's loudness contour control since I put the CX-600U in the main rig...don't know how I lived without it! Brilliant!!
I rarely use tone controls, but I must have them on certain recordings. And I'm a recent IC convert, just lowly Tara Labs Greens.Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
Easy on the name calling boys!
I would concur. Others have used that approach as well; for example the EICO HF-52 mono integrated tube amp I had in high school (itself of ca. mid-1950s vintage) had a flat 'level' control and a variable contour 'loudness' control that worked just like the Yamahas.
The only drawback to the Yamaha variable loudness was that the curves were based on the classic but now somewhat discredited Fletcher-Munson 'equal intensity perception' loudness curves.
You can see the Yamaha variable loudness contours,e.g., on page 20 of http://www2.yamaha.co.jp/manual/pdf/av/english/AFR/CR-2020.pdf -
Well, you guys have got me listening to my music with the loudness switch off all night. I am adjusting to it and I do hear some vocals more clearly (bohemian rhapsody)
Do the Fandando !!!:biggrin: Do what sounds right to you and not what any know it all on here say's is best, correct, optimal, blah blah blah !
Maybe a set of earphones will eliminate the need to keep the volume down and the loudness switched on.
Kenneth Swauger wrote: »Easy on the name calling boys!
Uh-oh, somebody's about to get a spanking! :eek: -
The need for "loudness" also depends on your speakers. Some are able to produce a full range sound at low volume without compensation. For example, my RTA11TL's need no compensation but smaller bookshelf speakers like the Monitor 5 benefit from a little boost at low listening levels.
StanStan
Main 2ch:
HT:
Other stuff:
loudness... I have that feature on my low $$$ pre but never use it... I find it's just not needed ..... bohemian rhapsody kicks
This is what I've figured out about tone, loudness etc.... If you set everything up right, including your room, and it measures reasonably flat at the listening position, then if the recording sounds like ****, it means the recording sounds like ****. It doesn't mean you should start fiddling knobs trying to make it sound like not-****.
So I'm a semi-purist in that I have a balance and a volume, but nothing else. Don't see the need for any other fiddlewidgets in my set up.
And to the snarky commentor above, no, I didn't remove the brakes from my car, since they're essential to it's operation, just like I would't rip the stylus out of my cartridge. However, if I was trying to make my car go faster, the A/C would be the first thing to go, since A/C isn't essential to the car's operation, and it sucks power even when it's not being used, just like most tone and loudness controls impede the signal even when they're not being used.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
No tone control on my preamp. Only three knobs. Volume, left gain and right gain. Nothing else.
I love how my system sounds right now. However, no doubt I will be swapping something out and trying a new piece sooner rather than later.
Guess I need to say this; Hi, my name is Beta and I am obsessed with this hobby.
For some it's the journey, not one destination. -
Only two knobs on my Integrated. Volume and source. That is all that is needed in my world.
I leave the bells and whistles for the HT setup. -
Hmmm....a Queen man, welcome to the Freddy Mercury club. Dig them too, but on the loudness switch, don't worry about it. You'll enjoy the Cambridge to no end and you can even have a short funeral service for that beloved loudness switch.
lsi 9's -
I see a little silhouetteo of an amp...
Last time I checked, I didn't see a loudness switch on any musical instrument.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
ABSOLUTELY.......it's really not a necessity at all, more of a crutch.
If you're going to a modern AV Receiver with a Sub out- get a musical sub and play with the crossover and volume... You'll find that it's much more flexible than a loudness switch and the results can be pleasently surprising.
Just my two half-pence worth.
wayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
