Four Dollar Wire
rebuy
rebuy Posts: 695
edited September 2011 in Basic Hookup/Wiring Questions
So I have the Onkyo and the rti4's ready to go except for a larger gauge wire.
We do have a Rat Shack which I've visited but I didn't want to buy Monster Inc.
I said to myself, "hey, go to the "True Value" hardware store and see if they have bulk wire to buy by the ft". So I did and they did, so we made the transaction and they kept the four dollars and I left with 20 feet of 16 gauge wire for the mains. Exciting isn't it?
When I bought the wire I noticed in the 16/2 mix that one of the jackets was slightly off color from the clear side and thought that is ok since it helps for polarity identification. How nice of the manufacturer to help by coloring the jacket. You know where we are going?
Well, it seems that one jacket is a green tinted because the wire on the inside of the jacket is corroded. Wasting away inside the true value hardware store and in my house. :eek:
You know, wire is wire, and this was a True Value
Thanks Paul
Good day
Post edited by rebuy on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2011
    www.monoprice.com
    100 ft of 12 gauge oxygen free wire for about $18
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited July 2011
    riveting tale.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • djperez81
    djperez81 Posts: 388
    edited July 2011
    TNRabbit wrote: »
    www.monoprice.com
    I bought a spool of that wire. Good bang for your buck!!
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    If you're looking for cheap and NOT green, Monoprice is a good choice. If you want something that's a few notches above that, still reasonably priced and hand made? www.signalcable.com with a Polk discount to boot.
  • matchan
    matchan Posts: 73
    edited July 2011
    monoprice is unbeatable for the price. cant imagine any other wire being better than this one - atleast better percieved sound quality
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2011
    Four dollar wire, four dollar sound.
  • TouchOfEvil
    edited August 2011
    four is a four letter word......:eek:
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    Monoprice wire turned green on me.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • headrott
    headrott Posts: 5,496
    edited August 2011
    To the original poster: IMO, skip that crap. Doro's suggestion about signal is good.
    Greg
    F1nut Posts: 51,749
    edited August 2011
    RuSsMaN wrote: »
    No truer words have been spoken here.
    tonyb Posts: 33,072
    edited August 2011
    Amen to that gents.
    4 buck wire ?? You would think new speakers deserve better.
  • rebuy
    rebuy Posts: 695
    edited August 2011
    I only had to make 2, 10ft runs, Even though I did want larger gauge wire I was thinking New wire from the "True Value" hardware store would be ok since it is 16 gauge.
    Remember I am in a very small town and choices are limited. Who would have thought that new wire was corroded on the spool?
    I posted this experience to warn others about shopping for wires.
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2011
    all I'm going to say is you get what you pay for.
    txcoastal1 Posts: 13,511
    edited August 2011
    rebuy wrote: »
    Corrosion is the main reason for oxygen free
  • decal
    decal Posts: 3,205
    edited August 2011
    Oxygen free is not really oxygen free
  • ROHfan
    ROHfan Posts: 1,014
    edited August 2011
    decal wrote: »
    Very true. Here's a good article on cable composition:
    http://www.audioholics.com/education/cables/exotic-materials-and-cable-construction
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    tonyb Posts: 33,072
    edited August 2011
    ROHfan wrote: »
    Here's a little bit of that article...read closely.
    "We have cut into pieces of Belden coaxial cable twenty-five years old that have been used in radio transmission applications--and found them clean and bright, completely lacking any sign of oxidation."
    Sure if you cut in the middle a cable,most will be free from oxidation because of the coating used, but it's not the middle that usually oxidizes, it's the ends,the connections. I also noticed he compares everything to broadcast cable where soundstage, presence, tone and weight have little to do with and not much of a concern broadcasting the 5 o'clock news.
    edited August 2011
    Interesting! I've, also, never seen anything but the ends corrode....even in cheap wiring. And I mean cheap!
    What's described above must be some pretty badly coated copper that's been stored in a super hot humid space for a while!
    But the other choices mentioned should address those problems.
    cnh
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited August 2011
    MonoPrice is def the way to go for cheap 12 gauge:)
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • RuSsMaN
    edited August 2011
    Monoprice has nothing to do with hi-fi. Basic listening, background music, sure. It will pass a signal, I'll give it that.
  • Mr. Sharpe
    edited August 2011
    haha ok thanks for that. All I'm getting from them are some Nanner prugs:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    heiney9 Posts: 25,432
    edited August 2011
    $4 sound isn't worth the effort of pushing the power switch.
  • TouchOfEvil
    edited August 2011
    cnh wrote: »
    cnh
    I have had a power cable turn green. Not home audio though lol. It was roughly 5 years old and in one of my cars a long time ago. The entire thing all the way through was corroded and green. Tore it apart and it looked like bakingsoda inside the wire strands.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • cembros
    cembros Posts: 172
    edited August 2011
    you get what you pay for I guess. Going cheep is a short term solution.
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2011
    Keiko wrote: »
    Moral of the story, the OP had to rebuy his speaker wires. :tongue:
    Why not take advantage of MIT's B Stock sale? Looks like they still have some left.
    http://www.mitcablesexpress.com/index.php?page=shop.browse&category_id=108&option=com_virtuemart&Itemid=14
    wow, those are great deals!
  • Mr. Sharpe
    edited August 2011
    My Dad's 12 gauge he had hooked to RTA 12c's were green once, but that was mostly because he procrastinates in getting new equipment slash upgrades for any of his stuff, except for his Cd player... that he doesn't use. but yeah, he probably had the same 12 gauge he put on them when he first purchased them lol I'm inheriting those so I'll have an all 100% original pair lol
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    Toolfan66 Posts: 18,040
    edited August 2011
    Post #29 reported for spam..
    tonyb Posts: 33,072
    edited August 2011
    4 dollar wire....5 dollar foot long....the worlds gone nuts I tell ya.
  • rebuy
    rebuy Posts: 695
    edited August 2011
  • TouchOfEvil
    edited August 2011
    Kim wrote: »
    Don't forget two large with any topping for 10 bucks....
    That's a good deal.:smile:
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
