Rolling tubes...
HRDROKN
Just thought I would start a thread with a specific subject....
Just to clarify some info...
Pre Dared MC-7P
In the 12AX7 position, the use of 12AT7 (-30% gain) would be to lower noise and require the amp to work a bit harder? And that would be good in this pre that is runs with Klipsch @ 102 dB sesitivity and a amp that can easily push 450 RMS?
Just tring to understand some basics....
Pre Dared MC-7P
HRDROKN
Klipsch KLF-30's, biamped, Carver M1.0t MKII .002 on the LF, Carver TFM-35x .002 on the HF, Marchand XM44, BBE2002R, Carver SDA-360. Carver Silver 7t's in the works....
Post edited by HRDROKN on
They are not that interchangeable. There are some differences in the voltages and heater currents that could adversely affect the amp. The mu factor is not the only difference that needs to be considered. There are more similar electrical substitutes (though some sites claim the 12at7 is OK). The link below has a good selection of possible substitutes.
http://www.duncanamps.com/tdsl/show.php?des=12Ax7integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Who stated you can run 12AT7's? If it wasn't the manufacturer of the gear I wouldn't do it. If you are looking for a lower gain compatible tube you can use 5751's, but the really good ones are pricey.
Do you have the pre-amp yet? Have you even run it in your system to verify it has too much gain. Now if Dared says you can run 12AT7's you might be alright. If you need a contact at Dared let me know. Did you buy your pre from Joe Zhou in Naperville, the US dealer? If so, he's a great guy that should be able to help you decide if the 12AT7's can be used in the 12AX7 position. Normally they aren't compatible.
The 5751 is electrically equivalant to the 12ax7 and has 30% less gain. That won't make your amp work harder, it will simply give you less gain out of the preamp, so only the preamp will work harder. The amp will continue to amplify whatever comes in.
What I'd suggest you look at is something like a single ended triode amp. Those are typically in the 8-12 watt range (but can be as low as 1-2 watts), which is probably plenty for your 102 db watt/meter speakers.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Sorry about that post.... I was mistaken about what I was thinking :redface:
I was in tube overload combined with beers... wasn't a good match! I got on that thought process from another thread, again more confusion on my part. I just checked and I ordered the correct 12AX7's for the 12AX7 position.HRDROKN
Klipsch KLF-30's, biamped, Carver M1.0t MKII .002 on the LF, Carver TFM-35x .002 on the HF, Marchand XM44, BBE2002R, Carver SDA-360. Carver Silver 7t's in the works.... -
What did you order? 5751's are lower gain and will work in that position."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
The pre should be here Thursday and I believe that it's coming from JPZ imports?
When I get it I plan not to change a thing until I get familiar with the sound as it comes... unless it totally sounds like a$$! After I get some time on her, I'll then do one change at a time.HRDROKN
I ordered the Sovtek 12AX7 LPS as suggested...HRDROKN
Those should get you started"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
